Inventor General
Message 1 of 8 (241 Views)
Inventor modeling instructions
241 Views, 7 Replies
08-22-2013 10:18 AM
Hi, I am trying to make a table top that will flip over and i need some weird parts. I am a revit user, but i want to get better at inventor. So I made this part in revit (see attached) and i exported it to dwg. the problem is that autocad doesnt recognize it as 3d printable, and neither does inventor. So i guess my question in 2 fold: How do I make something from revit into an stl file (3d printable)? And how in the world do you make this part in inventor? (see attached) If you have a good you tube video or something for more advanced modeling methods, I would really appreciate it. Thanks!
karthur1
Message 2 of 8 (233 Views)
Re: Inventor modeling instructions
08-22-2013 10:54 AM in reply to: michaelmead
Not familiar with Revit at all.  Will it save as .stp or .sat?  If so, read that format into Inventor.
Message 3 of 8 (219 Views)
08-22-2013 11:10 AM in reply to: karthur1
No I cant. I simply export it as a dwg, but when I load it into inventor, I cannot get an STL file out of it??
karthur1
Message 4 of 8 (202 Views)
08-22-2013 11:39 AM in reply to: michaelmead
check youtube...  http://www.youtube.com/watch?v=4-WDJvBe1rU
At around 2:20 in this video, he exports out to SAT.  That is what you need to read this into Inventor...... not DWG.
Message 5 of 8 (195 Views)
08-22-2013 11:48 AM in reply to: michaelmead
Just out of curiosity - attach the Revit dwg file here.
(did you set the Options on Export/Import)?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 6 of 8 (149 Views)
08-22-2013 04:56 PM in reply to: JDMather
it wont let me it gives me the error message "The contents of the attachment doesn't match its file type."
Valued Mentor
Message 7 of 8 (144 Views)
08-22-2013 05:25 PM in reply to: michaelmead
Hi
Try this.
Start Inventor then browse to your dwg file and select it. Do NOT click 'Open' instead select the options button that should now be active and change the option from open to import. This will convert you dwg to an ipt file that you can save. To create an STL file go to Save Copy As and change the file type to STL.
Regards
Martin
Edit : Don't know what version of Inventor you have but 2014 can open / import rvt with out needing to go through dwg. Just change the file type drop down in the Inventor 'open' dialogue box.
PDSU 2014 SP1.3
Windows 7 64bit SP1, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 580GTX Graphics (Diver 327.23)
256GB SSD OS, 80GB SSD working folder
Space Pilot
Message 8 of 8 (131 Views)
08-22-2013 06:04 PM in reply to: michaelmead
There has been a problem lately with attaching files here.
Right click on the filename and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
