Hey, guys,
I'v suddenly ran into problem. Not a big deal, but still it's frustrating.
When I transfer something that in real world is 10 milimeters in Inventor it becomes 100. And if I want to (for example 3d print some parts) I have always to scale 10 times, because inventor 10 milimeters are 1 in the real world. Why and how to fix it?
Solved by JDMather. Go to Solution.
Hi Aki,
with "transfer" do you mean "import"?
You can set the unit in the import process.
I hope that it can helps you.
Admaiora
After all the problem is somewhere:
how to change inches to milimeters maintaining value. If it was 43,5 in inches tu convert to 43,5 in milimeters. Thanks in advance
@aki.maxis wrote:
When I transfer something that in real world is 10 milimeters in Inventor it becomes 100. And if I want to (for example 3d print some parts) .... Why and how to fix it?
What do you mean "transfer something"?
Import?
Export?
File type?
You mention 3D printing.
When Save Copy as Type *.stl did you set the Units in Options?
Attach your files here and end all doubt.
(you haven't even indicated what version of Inventor and Service Pack)
@aki.maxis wrote:
how to change inches to milimeters maintaining value....
Type in the desired units.
43.5 in
