I'm having a problem with Inventor 2013 closing when I insert a base view of an .iam into an .idw. This problem does not occur when inserting a base view of an .ipt. Has anyone encountered this problem before?
Is this reproducible using any assembly? Or just one special dataset? I can't reproduce using a common assembly on R2013.
For those of you that update your video card drivers on a regular basis, beware that doing this could effect Inventor .idw's. In a .idw I was unable to insert a base view of an assembly, however I could do a part just fine. After extensive research, I found that my video card driver that I had updated recently was the problem. After exhaustive research on the internet for the proper driver, I finally found the driver that fixed the problem.
So be cautious when updating video drivers.
Bill Bedore
