Inventor Forum
Inventor hangs when importing Step files
17 REPLIES 17
Message 1 of 18
tmulligan
4628 Views, 17 Replies
Inventor hangs when importing Step files. I have tried unchecking the embed in document option with no luck. Is there anything else I can try?
TIA
Tom
17 REPLIES 17
Message 2 of 18
JDMather
in reply to: tmulligan
You have provided almost no useful information for the purpose of diagnosing your problem.
Q1. Can you save a simple cube as STEP?
Q2. Can you then open this simple STEP file that was created by Inventor in Inventor?
Q3. Is this a new problem on this install, did it work once, or did it never work?
Q4. What version of Inventor?
Q5. All Service Packs and Updates?
Message 3 of 18
mcgyvr
in reply to: JDMather
"embed in document" is ONLY for the translation report and I'd hope would have NO impact on the actual import process other than where to save the text file that says it was imported,blah blah blah....
Message 4 of 18
tmulligan
Q1
Yes I can create a step file in inventor.
Q2
I can import the file back into inventor
Q3
This happens to me with large files. I am trying to open a 357MB file
Tom A. Mulligan
DGE Inc. an FEV company
Desk 248.293.1348
Fax 248.293.1309
Email tmulligan@dgeinc.com
www.dgeinc.com
www.fev.com
Message 5 of 18
JDMather
You left out the critical information in Q3 in your original post (and the related information that it works fine on small models).
You did not answer the last two questions.
Q6. System Specs?
Q7. Have you turned off quality checking and set to save parts on open.
Message 6 of 18
JDMather
in reply to: mcgyvr
@mcgyvr wrote:
"embed in document" is ONLY for the translation report and I'd hope would have NO impact on the actual import process ...
Actually there was a bug in an earlier release where turning this off did allow the translation.  I think it was fixed in a SP.
Message 7 of 18
tmulligan
Q7
Running Inventor 2013 on Windows 7
Processor intel i7-2720QM CPU 2.20GHz
8GB RAM
64 - bit OS
Q8
I do not see a quality checking option for STEP import.
[cid:image001.jpg@01CEF1CE.ED1C1280]
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
Message 8 of 18
JDMather
Make sure Post Processing
Check Parts during load
and
Auto Stitch
Advance Healing
are turned off.
Make sure to have Save Components during Load is active.
8Gig might be too little for a file that size.
Message 9 of 18
tmulligan
Thank you for your help I will inquire about more RAM.
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
Message 10 of 18
JDMather
I'm not convinced that RAM will solve the problem.
Can you send me the file or post it on Autodesk 360?
jmather_at_pct_dot_edu
Message 11 of 18
tmulligan
I am trying to upload the file to Autodesk 360. It will take a while.
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
Message 12 of 18
JDMather
I tried opening in Inventor 2014 set to Solids only.
The file opened - but nothing there - no solids.
I tried opening in 2014 & 2013 filtered for Surfaces only.
Crashed both.
I tried opening in Creo 2 but it failed (but no crash like Inventor).
I tried importing in to Fusion 360, but could not figure out how.
Edit: finally got an email that import into Fusion failed.
I tried opening in SolidWorks 2013 and it successfully opened (780 solid bodies, 2213 surface bodies) in about 20 minutes (comp specs below).  The file has a modeled wire screen mesh  (not sure if it is ok with OP to post screen shot here).
Message 13 of 18
tmulligan
Ok, thanks for all that work but what does that mean for me. Are you saying I need to find some one with Solild works?
Message 14 of 18
JDMather
Either that, or wait a few days and see if I get a chance to repair the file and send it back to you.
I suspect that Autodesk might be interested in this file for testing purposes.
Is it OK to distribute, and if so, any limitations?
Message 15 of 18
CESAR200
Hello Tom,
Can you give me access to your file?  I'd like to do some tests with it and see if there's really a problem to import it in Inventor 2014.
I can enable a FTP site for you to upload the file if necessary.
Cesar Valencia
Product Support
Message 16 of 18
tmulligan
OK, but please do not distribute. Please send me the ftp info.
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
Message 17 of 18
CESAR200
Hi Tom,
Thanks for sharing the STEP file.  I found no problem opening it in Autodesk Inventor Professional 2014 SP1 with Update 1.  I used a computer with 12 GB RAM and it took about 20 minutes to import it.  The file contains solids and surfaces and the translation report shows some warnings.
I'll do some more tests with Inventor 2013 and will report my findings to you.
Cesar Valencia
Product Support
Message 18 of 18
CESAR200
Hello Tom,
I posted the Inventor part files to the FTP site.  I imported the file in Inventor 2013 and 2014 so you will find 2 files there.
The import process takes a long time if you enable the option 'Import into Repair Environment'.  If that option is disabled, the process is much faster.
There were some warnings in regards to the quality of the imported surfaces.  Please take a look at the translation report in the model browser for more details.
If you have any questions please let me know.
Cesar Valencia
Product Support
