Inventor General
Active Contributor
tmulligan
Message 1 of 18 (490 Views)
Inventor hangs when importing Step files
490 Views, 17 Replies
12-05-2013 11:46 AM
Inventor hangs when importing Step files. I have tried unchecking the embed in document option with no luck. Is there anything else I can try?
TIA
Tom
JDMather
Message 2 of 18 (487 Views)
Re: Inventor hangs when importing Step files
12-05-2013 11:50 AM in reply to: tmulligan
You have provided almost no useful information for the purpose of diagnosing your problem.
Q1. Can you save a simple cube as STEP?
Q2. Can you then open this simple STEP file that was created by Inventor in Inventor?
Q3. Is this a new problem on this install, did it work once, or did it never work?
Q4. What version of Inventor?
Q5. All Service Packs and Updates?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
mcgyvr
Message 3 of 18 (483 Views)
12-05-2013 11:53 AM in reply to: JDMather
"embed in document" is ONLY for the translation report and I'd hope would have NO impact on the actual import process other than where to save the text file that says it was imported,blah blah blah....
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Contributor
tmulligan
Message 4 of 18 (478 Views)
12-05-2013 12:13 PM in reply to: tmulligan
Q1
Yes I can create a step file in inventor.
Q2
I can import the file back into inventor
Q3
This happens to me with large files. I am trying to open a 357MB file
Tom A. Mulligan
DGE Inc. an FEV company
Desk 248.293.1348
Fax 248.293.1309
Email tmulligan@dgeinc.com
www.dgeinc.com
www.fev.com
JDMather
Message 5 of 18 (474 Views)
12-05-2013 12:18 PM in reply to: tmulligan
You left out the critical information in Q3 in your original post (and the related information that it works fine on small models).
You did not answer the last two questions.
Q6. System Specs?
Q7. Have you turned off quality checking and set to save parts on open.
JDMather
Message 6 of 18 (472 Views)
12-05-2013 12:24 PM in reply to: mcgyvr
mcgyvr wrote:
"embed in document" is ONLY for the translation report and I'd hope would have NO impact on the actual import process ...
Actually there was a bug in an earlier release where turning this off did allow the translation.  I think it was fixed in a SP.
Active Contributor
tmulligan
Message 7 of 18 (470 Views)
12-05-2013 12:31 PM in reply to: tmulligan
Q7
Running Inventor 2013 on Windows 7
Processor intel i7-2720QM CPU 2.20GHz
8GB RAM
64 - bit OS
Q8
I do not see a quality checking option for STEP import.
[cid:image001.jpg@01CEF1CE.ED1C1280]
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
JDMather
Message 8 of 18 (462 Views)
12-05-2013 01:30 PM in reply to: tmulligan
Make sure Post Processing
Check Parts during load
and
Auto Stitch
Advance Healing
are turned off.
Make sure to have Save Components during Load is active.
8Gig might be too little for a file that size.
Active Contributor
tmulligan
Message 9 of 18 (457 Views)
12-05-2013 01:52 PM in reply to: tmulligan
Thank you for your help I will inquire about more RAM.
Tom A. Mulligan
Desk 248.293.1348
Fax 248.293.1309
www.dgeinc.com
www.fev.com
JDMather
Message 10 of 18 (455 Views)
12-05-2013 02:13 PM in reply to: tmulligan
I'm not convinced that RAM will solve the problem.
Can you send me the file or post it on Autodesk 360?
jmather_at_pct_dot_edu
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
