I have what is to me a rather large assembly. 1823 total occurrences in the active document and 700 open documents in the session.
My problem is that when I open the assembly nothing shows up on the monitor in the image area. The tree is fully populated an showing visibility on all the parts.
I have tried saving as a different level of visibility and still no go.
Any ideas would be helpful.
Sorry if this sounds like an insulting question, but did you press your "Home" or F6 keys to recenter the assembly in the window?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hmmm,... try rebuild all? What version of IV is this?
Can you post a screen shot with the model tree in it?
Chris Benner
Rebuild didn't make any change in the view. When I picked it it appeared to be working but again no change in the display.
Attached is the screen shot.
Thanks for the help.
I'm afraid I have no clues, then. have you shut down and restarted? Might be you have a memory leak, and just need to clear things out.
Sorry I don't know more.
Chris Benner
Hi richweiss1513,
You didn't mention the version of Inventor you're using, but I seem to recall this as a bug in a past version (Inventor 2011 maybe). I think the solution was to activate the Master View Representation, and it would bring back the missing components.
You might also look into installing the latest service packs if you've not done so.
I hope this helps.
Curtis
I notice in the browser that one of your parts is a surface body.
Another shot in the dark -
Delete that and any other suface bodies or imported parts.
Try changing back and forth between View Reps (post screen shot of your View Reps).
(did you check on other assemblies and they work as expected?)
Hi richweiss1513,
Does setting Inventor to use Software Graphics do anything?
http://inventortrenches.blogspot.com/2011/01/graphics-issues-application-options.html
I hope this helps.
Curtis
@Anonymous wrote:Here is a shot my view reps attached.
What happens if you double click on the locked Master view rep?
What happens if you open another assembly?
When I click on the Master view I do get a display but it is not one I save in a Level of Detail.
I can open different assemblies with no apparent problems.
Sorry but I'm not sure if I know how to make a sketch in an assembly without picking a surface to put the sketch on. Could you describe how to do it?
thanks
Rich
@Anonymous wrote:When I click on the Master view I do get a display but it is not one I save in a Level of Detail.
Uhmm, did you lock that user created View Rep after creation?
Sounds to me like it somehow got saved in a different state.Can't you create a new one while in Master View and move on? (be sure to lock it once you have it set up)
