Inventor General
Member
ipburbank
Message 1 of 2 (115 Views)
Inventor change default normal
115 Views, 1 Replies
01-18-2013 08:09 PM
When placing a transitional constraint to a surface (the part has no volume) the default normal is inconveniently on the wrong side of the face. Is there an easy way to change the default normal for future constraints? (92 objects have this constraint applied to themselves and the surface).
Istvan.
*Pro
sbixler
Message 2 of 2 (83 Views)
Re: Inventor change default normal
01-20-2013 04:35 PM in reply to: ipburbank
I can't see any way to change this, and I can see how it would be quite tedious if you have many such constraints to place.  Select Other allows you to select the other normal of a surface, but that's a lot of extra clicks to do the job.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
