Inventor General
Valued Mentor
stephengibson76
Message 1 of 3 (237 Views)
Inventor and AutoCAD sheet sets
237 Views, 2 Replies
07-18-2012 02:50 AM
Is there a way to link sheet sets in autoCAD with Inventor idw's?
Basically we do the initial design in Inventor then basic drawings and drop them into AutoCAD to detail up at a later date.  The crossover timing to autocad is always contensious because we break the link with the model.
we need to issue draft drawings from inventor so the titleblock etc needs to be filled in correctly and we are looking for a way not to redo the work in autocad but also use the sheet set manager
Stephen Gibson
View stephen gibson's profile on LinkedIn
Curtis_Waguespack
Message 2 of 3 (222 Views)
Re: Inventor and AutoCAD sheet sets
07-18-2012 08:30 AM in reply to: stephengibson76
Hi stephengibson76,
You can't use AutoCAD sheet sets with IDWs, but you can if you convert the IDW to an Inventor DWG file. Recall that an Inventor DWG is just like an IDW but with added funtionality.
http://inventortrenches.blogspot.com/2011/05/using-autocad-sheet-set-manager-with.html
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0074-Getting_74/0115-Document115...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Mentor
stephengibson76
Message 3 of 3 (216 Views)
07-18-2012 08:55 AM in reply to: Curtis_Waguespack
Thanks,  this seems to work quite well and also creates a buffer so the drawings remain associated to the model for longer before they are autocadded out and link broken
Any problems with inventor dwg's other than filesize?
Stephen Gibson
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
