We have a number of users, who use Inventor Viewer to view .IDW drawings. The newest Inventor Viewer 2013 just disappears (closes) when you open the second drawing. You have to start the Viewer again for each drawing. It happens on both 32-bit and 64-bit version of the viewer and on different machines. It worked on Viewer 2012.
Also the Open Dialog box is very small and can not be resized to something bigger and useful.
When can we expect a working release of the Viewer ???
regards,
Jorn
Solved by rangt. Go to Solution.
We're aware of the issue opening the second document. This will be fixed in the 2013 View Sp1 due out shortly.
