Imagine, You changed some feature of the part but you didn't open the drawing. And you tryed to open drawing by the InventorViewer. In this case drawing file comes to Viewer with old state...
This is really big problem. You need to open all drawings once to update all drawings.
Any solution?...
Mucip:)
mucip
This is as Inventor is designed.
Until you tell Inventor to update your IDW/DWG it does not know to update it.
Do you want to update all IAM, IPN and IDW/DWGs that reference this part?
Saving this part refreshing all designs and documents that reference this part could be a time consuming task.
Do others on the forum have a solution for mucip?
Good luck.
Dear Bob,
Thanks for replay. I found below API solution with VB Express 2010. I just wrote it and will try tomorrow.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = asmDoc.AllReferencedDocuments
Dim invDocument As Document
Dim drawDoc As Inventor.DrawingDocument
Dim Salla As String
Me.Cursor = System.Windows.Forms.Cursors.WaitCursor
For Each invDocument In oRefDocs
Salla = FilePath(invDocument.FullFileName) + "\" + BaseFilename(invDocument.FullFileName) + ".idw"
If IO.File.Exists(Salla) Then
drawDoc = inv_App.Documents.Open(Salla)
drawDoc.Update2(True)
drawDoc.Save2(True)
drawDoc.Close(True)
End If
Next
Above code I will get all the referenced files in Assembly. If referenced file has IDW in same folder than I open it and save again...
I think this will be solution for me. Ofcourse it will take time when I run it...
Any better solution?...
Mucip:)
Yes but in any case Inventor Viewer should update itself when I try to open any idw of the part... I think there is something wrong here?!...
Mucip:)
This is incorrect. Inventor Viewer does exactly what it says: it views. Updating the drawing requires opening Inventor proper (or apprentice, which is pretty much a minimalized version with no GUI).
I do not think so! You say "Just view...". OK. If it Views wrong drawing or model so what will we do with Viewer?!...
Is it just for showing un-updated drawing?!... How will I trust Viewer than?...
In my opinion this is not correct!. Yes it's free but it must update but just update! Not more...
Mucip:)
Mucip:)
This is no different than most software packages; not just CAD, either. Even Adobe Reader works this way. Updating is an edit, and edits are not allowed with a viewer. Updating drawings is a chore that all design houses have to deal with. It's just a part of life.
