Inventor General
Active Member
klange
Message 11 of 19 (69 Views)
Re: Inventor View Font
11-28-2006 06:38 AM in reply to: klange
Tahoma - I believe Inventor defaults to this font. We have not changed it.
HP LaserJet 8100
Distinguished Contributor
billco-mfg
Message 12 of 19 (69 Views)
11-28-2006 09:34 AM in reply to: klange
What version are you using? I had a similar problem at some point with IV10. There was some sort of update to correct the problem.
Inventor Routed Systems 2010
Subscription Advantage Pack SP3
Vault Collaboration 2010
Windows 7 x64
Dell Precision M6400 Covet
Active Member
klange
Message 13 of 19 (69 Views)
11-28-2006 12:14 PM in reply to: klange
IV 11. There are updates available for Inventor View as well, but they do not resolve the problem.
Active Member
klange
Message 14 of 19 (69 Views)
11-28-2006 12:19 PM in reply to: klange
I received this information from an Autodesk support technician...
I have done some additional research and have found the following information.
This is a known issue with the viewer. When translating the text, the viewer is taking it from a much larger area than Inventor and it tries to maintain the aspect ratio. In doing this, the fonts can get cramped together or even run on each other.
I don't have an ETA on a change in behavior for this or even if it will be changed. The whole thing to remember is that the viewer is just that, a viewer - not meant to necessarily print the files, however I can imagine the need for a QA technician, etc. to want to do that.
The only workaround at this time is re-scaling it from the viewer to make the change in text appearance less noticeable.
billco-mfg
Message 15 of 19 (69 Views)
11-28-2006 12:41 PM in reply to: klange
"The whole thing to remember is that the viewer is just that, a viewer - not meant to necessarily print the files..."
Did you make up that part?
Windows 7 x64
Active Member
klange
Message 16 of 19 (69 Views)
11-28-2006 12:45 PM in reply to: klange
That came straight from the support tech. Sounds like they don't know how to fix the problem and are using technicalities as excuses.
MattH
Message 17 of 19 (69 Views)
12-20-2006 01:36 AM in reply to: klange
This just in, not my own work, discovered on another forum
Change your default printer settings (via Control Panel) to match the desired output, then print using the default printer in Inventor View and all the font issue suddenly clear up.
It seems that if you change the printer settings from within Inventor View, it still tries to use the settings of the default print, but sends them to the selected printer.
Regards
MattH
billco-mfg
Message 18 of 19 (69 Views)
12-20-2006 05:33 AM in reply to: klange
This might be the same thing, but we've noticed that you need to use page setup in IV View in order to get a decent print. Changing options in the print window doesn't work so well.
Windows 7 x64
Active Contributor
dwing
Message 19 of 19 (41 Views)
04-17-2012 07:43 AM in reply to: klange
Thanks for this solution!  It has helped a lot.
Dan
www.yf.com
www.tactair.com
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
