What exactly do you mean by "Inventor tooling" ?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@stefaanboel wrote:
Tooling and mold design
You mean like HSMExpress?
http://www.idcm.info/nl/files/marketing/AIA2013_hands-on_InventorCAM_01.pdf
You're welcome
Regarding Mold Design I found only some short videos, nothing really new. But IMHO you could try to use what's on Autodesk WikiHelp on 2011 version, and there is a great tutorial by our fellow EE, JDMather - http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
Also not for the up to date version, but it will give you a gist of what's what.
Going way back to when it was first introduced the Mold design environment was called Inventor Tooling.
Originally there was a book published by Autodesk back then - but I haven't seen any book since.
I offer a class on the topic. (2 sections next fall)
