Inventor General
Active Member
Message 1 of 24 (2,110 Views)
Inventor Studio greyed out
2110 Views, 23 Replies
06-19-2012 07:17 AM
I'm a teacher and recently had Inventor Professional 2013 installed on my laptop. 2 of my co-workers have the exact same model of HP Laptop, yet they don't have the same issue as me.
When I finish my assembly, I access the Tools bar to find my Inventor Studio is greyed out and can't click it. This is a huge pain in the **** as my laptop is the only one at my training session that is having this problem in a room full of 40 other teachers. After several uninstalls and reinstalls, I have the same problem with no solution in sight.
Someone please help as Autodesk support hasn't been able to shed any other light on fixing this issue.
*Expert Elite*
Curtis_Waguespack
Message 2 of 24 (2,105 Views)
Re: Inventor Studio greyed out
06-19-2012 07:27 AM in reply to: cplach
Hi cplach,
It sounds like you've done some trouble shooting with AD, but you didn't mention what you've done other than uninstall / reinstall, so forgive me if you've already checked this:
Go to the Tools tab > Add Ins button  and look for the Studio Add-in. If it's there is it loaded?
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
Message 3 of 24 (2,104 Views)
06-19-2012 07:33 AM in reply to: cplach
Please see the attached screen shot. I have looked in the Add-Ins, it says Inventor Studio is Loaded and supposed to be automatically.
*Expert Elite*
DarrenP
Message 4 of 24 (2,098 Views)
06-19-2012 07:38 AM in reply to: cplach
does this happen with every file?
Active Member
Message 5 of 24 (2,090 Views)
06-19-2012 07:43 AM in reply to: DarrenP
Yes. No matter what file I open, it remains unavailable.
I've tried to create new assemblies but I still come across the same problem.
After disabling and re-enabling through the Add-Ins, I can click Inventor Studio now but all of the children options are greyed out.
Active Member
Message 6 of 24 (2,077 Views)
06-19-2012 08:28 AM in reply to: cplach
Tried to reinstall it again and it's still giving me the same problem.
Would this have anything to do with activating the product?
*Expert Elite*
Message 7 of 24 (2,065 Views)
06-19-2012 10:29 AM in reply to: cplach
No.
Did you follow the Autodesk Clean Uninstall document (search Google)?
Did you install with anti-virus and UAC turned off (important)?
Before you go through that again -
I noticed that you are showing from the Tools tab.
Instead of that go to Enviroments tab and select Studio
(once I do that I show an active Render tab and the button Studio button on the Tools tab is grayed out like yours).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
Message 8 of 24 (2,049 Views)
06-19-2012 11:04 AM in reply to: cplach
Doing a clean uninstall now. I'll report back in an hour or so with an update.
It doesn't really matter if you go through tools or environments to access Inventor Studio. It's executing the same command.
Active Member
Message 9 of 24 (2,042 Views)
06-19-2012 12:07 PM in reply to: cplach
no such luck.
*Expert Elite*
Curtis_Waguespack
Message 10 of 24 (2,036 Views)
06-19-2012 01:41 PM in reply to: cplach
Hi cplach,
I'm not sure if this will work with Inventor 2013, but maybe it's worth a try:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018
Another thing to look at would be user profiles. Can you log in under / or create a different user profile (as the admin possibly) and start Inventor to see if the issue persists? It seems that I recall issues of a similar type being resolved by recreating a user profile (maybe?)
I hope this helps.
Curtis
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
