so how can i avooid that camera flip ????
it is very unproductive.. cant make a proper fly thru without switching camera angle by 180....
i do not cross any axes either....
any workaround?
thanks for the help,
Richard
how many year/release's has the bug made the animate via path worthless?
why doesnt Autodesk put something in the help files about having to biuld your model so that the y axis faces up in the center of both paths before people spend a 1000 hours biulding a project?
is it embarassment that animate path works in autocad perfectly?
so much for smooth camera transitions in my animation.
@vamolino wrote:how many year/release's....
Don't know if it woud address this problem, but I've been waiting for an Inventor equivalent of MDT augmented "line" (actually curve) since I started using Inventor.
I agree.. This would be my final request from the MDT days....
JDMather wrote:Don't know if it woud address this problem, but I've been waiting for an Inventor equivalent of MDT augmented "line" (actually curve) since I started using Inventor.
@Dennis_Jeffrey wrote:I agree.. This would be my final request from the MDT days....We might be the only dinasours left who know (and how to use) a MDT augmented "line".
Or, how to blend two surfaces together with a patch... 🙂
Problem is caused when you create a part or assembly with non native Inventor home coordinates.
Industry standard for ground plane for surveying is XY plane.
Inventor uses ZX as ground plane, which cause all sorts of problems when importing other CAD data.
I change my template to suit XY industry standard which cause annoying glitches with Inventor.
To solve the animation camera rolling problem..
1. Create a new assembly file dedicated to you animation.
2. Place the assembly in this file and orient the base of the part ie; ground level, with the assembly ZX per the coloured triad at the bottom of the screen.
The camera shouldn't roll any more during animations.
Other tips..
3. When creating the spline paths, create one than offset the original for better control.
4. If you want to change the zoom midway through an animation, create a new set of spline paths wit linked to the ends of the first set, change the zoom and time settings for the new paths.
5. It helps to create the static camera as close as possible to the animation camera before animating the static camera. Attach work planes to the spline paths to use a a focus point. When setting up the static camera, set 'link to view' to help validate and set the initial focus and roll angle correct from the start. I find inventor doesn't respond well to edits later on.
This is so annoying on so many levels. And to see that it is tied to the STUPID STUPID default of ZX as a ground plane. XY is the ground plane in the real world of machining. Now I learn that so many of my problems stem from this DUMB decison of Autocad? Lame lame lame. Give the user the choice. Make it global. MAKE IT WORK RIGHT!
Folks,
I use Inventor 2015:
I experienced similar problems with rolling camera, on the beginning angle is set by me and it's correct. Along the movie camera is rolling out-of-control.
I thought that model is set up correctly, XY plane is base plane.
Short video with rolling camera:
http://www.filedropper.com/video11
All comments how to block camera angle wil be much appriciated.
LB
Some questions:
If a spline, can you edit the individual interpolation points and rotate them?
Alternatively you could try using a camera target path. May sound dumb, but it might work. Alternatively, create the camera path with normal (not spline) curves.
The rationale: it may be that the spline the camera is following has it's normals rotating around it. Or, the camera itself has no idea of "up" and just goes off doing whatever 'feels good'.
Giving a target path (copy the first path and shift it so starting points are apart from one another) may tame the beast. Once upon a time there was a skill builder for Advanced Camera Animation that provided an example for this process. Skill builders are gone, but not forgotten it appears: http://www.scribd.com/doc/33254847/Autodesk-Inventor-Advanced-Camera-Animation (ignore the old UI)
When I get time, I'll try this as well to see if there are any other things that might help overcome the issue - in case the above doesn't work.
I have the same issue. I've tried all of the suggestions, and the camera still rolls. I agreed that this is ridiculous and annoying and when is Autodesk going to fix the issue. In the meantime I cannot complete a critical project!
The camera seems to rolls when it gets to the half way point of the path, double the length of the camera path ( add a straight line to the end ) and then trim the resulting animation in half
