I have an assembly inside of Inventor Studio. One of the parts inside of the assembly has a parameter that I would like to aniimate. When I select the "Parameters" function within the "Animate" tab on the ribbon, I get an error:
"There are no favorite parameters defined."
This worked fine when I tried the same thing with only the part inside of Inventor Studio, but not when the part is included inside of an assembly.
Does anyone have any suggestions?
Solved by blair. Go to Solution.
I don't have time to look right now, but I seem to recall that one of the Tutorials covers that topic.
You need to select the constrain / parameter in the Browser Window within Studio and RMB on it to add it to the Favorites
