Inventor General
New Member
PR_RamFan
Message 1 of 3 (196 Views)
Inventor Student Edition 2013 Model Import Gone Wrong
196 Views, 2 Replies
04-01-2013 02:05 PM
I have a project I'm working on and recently imported a model from grabcad.com.  Now, whenever I try and edit the project I get the message: "Cannot modify the library file *.iam Component *.iam is not checked out to you.  Edits are not allowed on this file."  the only solution I could find is purging the files, which I don't know how to do and it was supposedly removed in the 2013 update anyways.  I also get a message "The file is being saved in a library folder.  Because files in a library folder are not editable, once you save this file you will not be able to modify it.  Do you wish to continue?"  I have tried saving everywhere, even the C drive (which is obviously not a folder to begin with).  What have I done?  And how can I fix it?
Curtis_Waguespack
Message 2 of 3 (182 Views)
Re: Inventor Student Edition 2013 Model Import Gone Wrong
04-01-2013 02:16 PM in reply to: PR_RamFan
Hi PR_RamFan,
Here's a very similar post at this link from just a few weeks ago, there are some suggestions that might help:
http://forums.autodesk.com/t5/Autodesk-Inventor/Edits-are-not-allowed-on-this-file/m-p/3766560#M4602...
I suspect that the import destination file location is causing an issue here, you might provide more information about the file paths, including your Inventor Project path, and maybe some screen shots.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
PR_RamFan
Message 3 of 3 (167 Views)
04-01-2013 02:44 PM in reply to: Curtis_Waguespack
They are both (importer and importee) saved in Public Documents, but I have tried moving them to every other place I can think of (Desktop, C Drive, flash drive, etc), Even after deleting the component that resulted in the problem, the message persisted.  Unfortunately, I have made no backups that don't have the same problem.  I think it's more of a Vault problem.  I was creating the project unconnected to Vault and the object I imported was "claimed."  I think somehow it took over my project.  Does that help at all?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
