Solved by mdavis22569. Go to Solution.
If you open your standard tempate and go to.. tools..document settings..units .. what is the document units?
I have verified that when using standard.ipt with simplify it changes document units to CM and when using sheetmetal.ipt the document units stay in inches..
You found a BUG!!! Squish it 😉
It has been reported..
For your future reference..
I use this form.. and Steve Dennis or one of the other guys watch those all the time..
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
I have quite a large assembly i want to simplify, but when i come to do this it doesn't show any templates available in the template box. i've tried creating them but the still don't show in the box. does anyone one know how i do this?
Thanks.
I would have started a new thread for this problem description as it doens't seem to be anything like the problem description in the original post.
Do you have your templates in the standard location?
Are you using projects with templates path pointing to a location other than the default location?
Have you installed the Service Pack and Updates?
Click on the white page (Browse Templates) and post screen shot of the resulting screen here.
