Inventor General
Active Member
bartlomiej.krysiak
Message 1 of 13 (560 Views)
Accepted Solution
Inventor Proffesional 2012 isn't starting
560 Views, 12 Replies
06-12-2012 05:36 AM
After I turn on the Inventor the welcome screen shows. After a 10 seconds it disappears without any error information. I can see in manage window that process “inventor.exe” is starting and disappears in the same time when welcome screen disappears. I have managed to repair this problem by uninstalling Inventor and Installing it again. But the problem shows up again after two weeks. The same happened when I reinstalled it again. I have installed service pack 2 for Inventor.
*Expert Elite*
Cadmanto
Message 2 of 13 (557 Views)
Re: Inventor Proffesional 2012 isn't starting
06-12-2012 06:08 AM in reply to: bartlomiej.krysiak
When did this start happening?
Is your master project file still accessible?
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
*Pro
ampster
Message 3 of 13 (547 Views)
06-12-2012 06:54 AM in reply to: bartlomiej.krysiak
more info needed,
system specs
have you looked thru the Event Viewer to see if anything might suggest why this is happening?
Active Member
bartlomiej.krysiak
Message 4 of 13 (531 Views)
06-12-2012 02:48 PM in reply to: bartlomiej.krysiak
I have the same situation on two of my computers: one is Win7 and other is WinXP.
I have some information from Autodesk Support Team.
In the file "INVPROSA2012PLKAdLM.log" I have error:
3364    2012/06/12    16:57:08    Reason=Fatal error
3364    2012/06/12    16:57:08    ComputerName=BARTLOMIEJK-LAP
3364    2012/06/12    16:57:08    OS=6.1.7601.Service Pack 1
3364    2012/06/12    16:57:08    File=AdlmIntSATSLicense.cpp,Line=416
3364    2012/06/12    16:57:08    VendorID=2 [ADLMACT]
3364    2012/06/12    16:57:08    VendorError=101 [The license cannot be accessed/loaded/opened]
The solution of this problem is described on page
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15176093&linkID=9240617
(my case is standalone version).
I have changed the name of file "adskflex_*_tsf.data" and it didn't help. New file  "adskflex_*_tsf.data" wasn't created after turning on the Inventor.
In the file "adskflex_00691b00_event.log" I found other error:
16:57:08 12-06-2012  [P:3704],[T:3684]     EventCode: 20000005, Message: Our service is disabled.
16:57:08 12-06-2012  [P:3704],[T:3684]     Exception: 59, Module: f0000, Location: 10
Maybe this will help to identify my problem.
*Expert Elite*
TravisNave
Message 5 of 13 (526 Views)
06-12-2012 03:06 PM in reply to: bartlomiej.krysiak
You might have to rename the ProductInformation.pit file as well as the license files.  Then reinstall fresh.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
bartlomiej.krysiak
Message 6 of 13 (525 Views)
06-12-2012 03:13 PM in reply to: ampster
Situation is the same on both of my computers (one is Win7 and second is WinXP).
On both of my computers Inventor was working properly. First time I had this situation couple months ago. Now is the same.
There is nothing suspicious in event log.
Active Member
bartlomiej.krysiak
Message 7 of 13 (523 Views)
06-12-2012 03:19 PM in reply to: TravisNave
Reinstall fresh - what does it mean? Uninstalling and fresh installation always helps (I tested it before), but it is quite annoying procedure.
Active Member
bartlomiej.krysiak
Message 8 of 13 (498 Views)
06-14-2012 04:53 AM in reply to: bartlomiej.krysiak
Can anyone help me with this problem?
Product Support
VinodBalasubramanian
Message 9 of 13 (489 Views)
06-14-2012 07:33 PM in reply to: bartlomiej.krysiak
They were suggesting a clean uninstall & reinstall of Inventor for a quicker resolution to this problem. Software corruption can be resolved with a clean reinstall most of the times. Please try to back up your custom templates and other customizations before doing a clean reinstall.
Below utility can help you remove your product cleanly from your machine,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17031128&linkID=9240617
You can follow the clean reinstall procedure as given below,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2893432&linkID=9240617
Hope it helps.
Vinod Balasubramanian
Active Member
bartlomiej.krysiak
Message 10 of 13 (487 Views)
06-15-2012 12:41 AM in reply to: VinodBalasubramanian
Hello. I tested it before and reinstallation resolves this problem. But I don’t won’t to reinstall Inventor every month on both of my computers. As I wrote earlier this problem always comes back after couple of weeks after reinstallation of Inventor. I’m looking for a stable solution of this problem without using reinstallation over and over again. Best regards, -- Bartłomiej Krysiak
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
