Inventor Forum
Inventor Part Files keep Updating after Save
11 REPLIES 11
Message 1 of 12
PafecDOGS
959 Views, 11 Replies
Hi, i am having a problem with Inventor 2014 (SP1 Update 2) concenring part files; whenever you do a change, then go to save, the file saves then the update icon turns on - even tho there's nothing to do/the change i've made has already happened. Even something like adding a chamfer does this; I add the chamfer; the chamfer is there, the update icon is off, I save the file then the update icon comes on, and if you exit it comes up with "Save Changes ?". its really nnoying, want to know if there's a solution; maybe some option i havent got ticked in Inventor. Thanks.
11 REPLIES 11
Message 2 of 12
brian
in reply to: PafecDOGS
Is there by any chance an iLogic rule firing "after Save"?
Message 3 of 12
PafecDOGS
in reply to: brian
Hi, not sure as I don't think we use iLogic here .... can you suggest where i would look?
There are 7 of us and we are all suffering this issue; we are wondering now if its started happened since we updated Inventor to the SP1 Update 2; it seems the problem may have started since then (we only did the update around a month ago) although none of us are sure ...
Message 4 of 12
blair
You are behind on your SP's and Updates for IV2014. That would be my first place to look.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 12
rdyson
View / Windows / User Interface / iLogic Browser
Will show what's loaded in a document
Manage / iLogic / iTrigger
Will show which routines are triggered by what action
PDSU 2016
Message 6 of 12
mrattray
Sounds like someone added some sloppy iLogic programming to your template.
Mike (not Matt) Rattray
Message 7 of 12
PafecDOGS
in reply to: rdyson
Yes, the part files have an iLogic rule - i remember now one of my colleagues adding something to do with something that convers mm2 to m2, but I didnt realise he added it thru iLogic. Unfortunately, he's in Australia til end next week, so i'll tackle him about it then. Can't wait to tell him his work is sloppy, i will enjoy that! Cat Tongue
Thanks for help
Message 8 of 12
admaiora
Smiley Very Happy  rascals colleagues
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 9 of 12
PafecDOGS
Just as a matter on interest, I've taken a snapshot of the rule thats been added to the Part File template - was wondering if anyone knows what i need to change to get it to work properly ...
Message 10 of 12
admaiora
if your template is set to mm, and you want mm, then you can delete, suppress or sett as comments the rule.
Admaiora
Message 11 of 12
mrattray
Try this:
If ThisDoc.Document.Dirty = True Then
	Area = iProperties.Area/(1e+06)
Message 12 of 12
PafecDOGS
in reply to: mrattray
I think that may have done the trick! I've changed the template and we'll see how it goes; the test part i tried seemed to be ok
Kudos² to you sir!
