Inventor Forum
Inventor LT 2014 Trial Version Failed to Install Due to Network Failure
2 REPLIES 2
rcuevas2626
258 Views, 2 Replies
I continually get this error code when trying to install Inventor 2014.  Is there a workaround or do I need to be hardwired to the net rather than through wifi?
Any suggestions would be most appreciated!
Robert C.
2 REPLIES 2
Cadmanto
in reply to: rcuevas2626
What method are you doing to try and load it?  Are you trying to download it off of the net?
Can you provide an image of what error you are seeing?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
rdyson
Here's a similar discussion on the Design-Review forum.
Might be related.
http://forums.autodesk.com/t5/Design-Review/Autodesk-Design-Review-installation-fails/m-p/4321663#M1...
PDSU 2016
