I continually get this error code when trying to install Inventor 2014. Is there a workaround or do I need to be hardwired to the net rather than through wifi?
Any suggestions would be most appreciated!
Robert C.
What method are you doing to try and load it? Are you trying to download it off of the net?
Can you provide an image of what error you are seeing?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
