Inventor Forum
Inventor Graphic card Nvidia Quadro 2000 VS Sapphire HD7850
14 REPLIES 14
Message 1 of 15
RobertKarlsen
2491 Views, 14 Replies
Hello 🙂
Im new on this forum, and my english isn`t the best....
But i will try 🙂
I have an 1.5 year old computer with specs like this:
Sapphire HD7850 graphic card
Intel core i5-3570K cpu 3.4 ghz
8 GB RAM
64 bit system
Windows 7
Now, I want to buy a "CAD" card from a friend of mine, the card is Nvidia Quadro 2000
I put it in a computer and download and install the drivers for the 3d studio max.
Then I open a inventor file and render an image.
With the new card, i can`t see that the rendering is going faster than the "old" game card.
What should i do? should i use my old graphic card or should i buy the card from my friend.
When do the quadro card works better than the other?
Greetings from Robert.
14 REPLIES 14
Message 2 of 15
blair
in reply to: RobertKarlsen
This is a good place to compare cards. http://www.videocardbenchmark.net/high_end_gpus.html
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 15
Logos_Atum
Due to the fact that the Quadro 2000 is quite old and it´s architecture not up to date,
you will probably be dependent on special cases to make the benefits show. I don´t
know if your Quadro has the lead in some applications but at least you can compare
the IRay Gpu supported rendering of your quadro to the Cpu only rendering with your
AMD card.
Given you switch to an openCL renderer for MAX the AMD card will beat your Quadro
thoroughly. As most of the applications are supporting direct 3D your gaming card will
probably be faster. Try Iray for the Quadro and LuxRender for OpenCL on your AMD card.
You can compare the wireframe performance as the optimized drivers tend to kick in there,
as they make far more refined use of the shaders present on the graphics card. Especially
AutoCAD should be faster.
Have a look for so called "Softmods". Those will allow you to install the FireGL drivers on
your AMD card. You will not regret that 😉
Kind regards
Daniel
Dogs aren´t flammable.
Message 4 of 15
dgorsman
If this is a question about rendering in 3DS MAX, I would suggest using that specific forum, even if the object was created in Inventor.
If you are still working in Inventor, could you elaborate on what you mean by "rendering"?  The graphic card may not have an impact on some operations.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 15
blair
in reply to: dgorsman
3dMax will allow you to select which CPU and GPU cores for rendering. The more cores you have and the faster they are, the better it will be for 3dMax.
Delta Tau Chi ΔΤΧ
Message 6 of 15
RobertKarlsen
in reply to: Logos_Atum
Ok,
But how do I find the appropriate drivers?
Do you have a link?
Thanks 🙂
Message 7 of 15
Logos_Atum
Hello there,
given you meant drivers with a softmod I can recommend theese. Softmods aren´t
locked out by AMD, so don´t have a hard time to think if it´s legal or not.
http://www.overclock.net/t/1403233/amd-firepro-modded-drivers-13-152-4-whql-for-radeon-cards-11-22-2...
The post sums up pretty much all the benefits and how it´s done. Been an add to the *.inf on the Nvidia side back
when I used one of their graphics boards.
After installing those drivers you should be able to use you 7850 as you would a FirePro W5000. Not completely but
fair enough for the money.
http://www.youtube.com/watch?v=Gls0hlq3aXM
This is pretty much what you can expect from the Mod
Kind regards
Daniel
Message 8 of 15
RobertKarlsen
Ahh.. I will try that one 🙂
Do you know, can i download same type of driver somewhere for a AMD FIREPRO V3900 1GB card?
Thanks for help!
Message 9 of 15
I get an error when i installed..
Do you know why?
Attached a screenshot
-Robert
Message 10 of 15
Logos_Atum
Hello there,
sorry for the late reply - yesterday was a bank holiday in Germany so I took my time 😉
I will have a look at it in the evening. Could you please send me the vendor ID of your graphics card as well as model specs and name?
I assume all we need to do is to include it in the list of valid cards for the driver install. They refere to this list in the link to the drivers I
posted and explain how to change them.
The 3900 should be supported rightaway with the standard AMD drivers. Those you can select on the AMD page I guess 🙂
Kind regards
Daniel
Message 11 of 15
RobertKarlsen
The install seems to be fine later that day. I uninstall all of the AMD software and now it work.
Message 12 of 15
Logos_Atum
Glad to hear that 🙂 Is it solved then?
Message 13 of 15
RobertKarlsen
Not actually 😛 yesterday i reinstall my pc, and now i cant install the drivers. I have tried several of times.
Where do i fint the vendor ID?
Message 14 of 15
Logos_Atum
Hello there,
sorry for replying late, I´m terribly busy at the moment. As I own a 7970 I don´t encounter those problems I guess.
Anyway, in order to get to know which GPU you actually have to add it to the list of supported cards in the driver
package download GPUZ. Start it and post a screenshot of what it displays to your follow up post.
I´ll try to add this entry in my spare- time and mail the modified list to you. Just send me a private message with your
e-mail address and a picture of you holding todays newspaper to the camera ;).
Just kidding - but seriously, just attach a screenshot and send me a message with your mail address.
Kind regards
Daniel
Message 15 of 15
RobertKarlsen
Hmm.. i can`t fint out how to send you a PM 😛
-Robert
