Inventor General
Cadmanto
Message 1 of 25 (468 Views)
Inventor Feature works?
468 Views, 24 Replies
03-22-2012 01:48 PM
For those of you that know Solidworks, they had a feature that could create features from dumb solids called featureworks.  Does Inventor have anything similar?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
jtylerbc
Message 2 of 25 (465 Views)
Re: Inventor Feature works?
03-22-2012 01:51 PM in reply to: Cadmanto
Yes, but it's an add-in, so you'll have to download and install it first.
http://labs.autodesk.com/utilities/feature_recognition/
John Tyler
Inventor 2013
Windows 7 64 Bit
CelticDesignServices
Message 3 of 25 (462 Views)
03-22-2012 02:02 PM in reply to: jtylerbc
Yeah, I really wish this was finally part of basic Inventor by now.
Labs has had this feature for a few realeses now and I use it all the time when dealing with vendor files.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Cadmanto
Message 4 of 25 (451 Views)
03-22-2012 03:05 PM in reply to: Cadmanto
Thanks.  I will try this when I get back to work.
We are using profressional so I am miffed that this ins't included as well.
Have you used it and if so what are your thoughts?
Best Regards,
Scott McFadden
Cadmanto
Message 5 of 25 (452 Views)
03-22-2012 03:07 PM in reply to: CelticDesignServices
Jim,
Me too!!!
I used it periodically when I was using Solidworks.  It was good for simple machined type parts.
Forget it on the ergonomic swept type parts.
Best Regards,
Scott McFadden
jtylerbc
Message 6 of 25 (444 Views)
03-22-2012 03:27 PM in reply to: Cadmanto
My thoughts are that I've never needed it badly enough to be worth the trouble of trying to get IT to install it for me . . .
John Tyler
Inventor 2013
Windows 7 64 Bit
Message 7 of 25 (429 Views)
03-22-2012 06:17 PM in reply to: Cadmanto
Identical to FeatureWorks.
I never use Automatic in Inventor or SolidWorks.
Use in manual mode and recognize only those features that will actually be edited.
You can multiple select then right click to combine circular or rectangular patterns.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Cadmanto
Message 8 of 25 (405 Views)
03-23-2012 11:01 AM in reply to: JDMather
Thanks JD.
My question now is I have downloaded it and when I go to the addins list I am not seeing it in the list.
How do I get it into my Inventor session?
I ahve already closed out of inventor and restarted that thinking that would work...Not!!!
Best Regards,
Scott McFadden
Valued Mentor
RayFeiler
Message 9 of 25 (402 Views)
03-23-2012 11:07 AM in reply to: Cadmanto
I guess no one likes Fusion?
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Message 10 of 25 (401 Views)
03-23-2012 11:08 AM in reply to: Cadmanto
You must install with anti-virus and UAC turned off.
I had the same problem on of my machines till I turned UAC off.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
