Inventor General
nkeeley
Message 1 of 9 (344 Views)
Inventor FEA simulation probe area
344 Views, 8 Replies
12-11-2013 02:15 PM
Hi all. So I've created a successful FEA simulation in Inventor 2014 and obtained results. But I want to see the highest stress in a defined area that is smaller than the entire part (I have some stress concentrations that are throwing off my 'max'). Is there a way to probe an area instead of just a point? I'm tired of creating a dozen probes to find the 'local max'.
Thanks!
Nathan
Employee
Bill-Ding
Message 2 of 9 (295 Views)
Re: Inventor FEA simulation probe area
12-16-2013 07:38 PM in reply to: nkeeley
Hi Nathon,
Good point! there are NO direct tools to show the local Max. value. But you can the Color Bar Settings and Contour Shading to get the Max. point which you want. I hope it can help you. Thanks.
-Bill
Bill Ding
*Expert Elite*
blair
Message 3 of 9 (285 Views)
12-16-2013 09:53 PM in reply to: nkeeley
You do have Max and Min boxes. Square box with little square box in lower LH and Upper RH corners. These will produce labels on the model with Min and Max values.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Distinguished Contributor
drguitarum2005
Message 4 of 9 (267 Views)
12-17-2013 06:46 AM in reply to: blair
I remember in 2013 there was a probe tool that would return the value based on where the probe was hovering. Was useful just to see the numbers quickly in an area. Now that has been replaced with a probe tool that requires you to click, and it adds a label with no obvious way to remove that label. What I end up with is 800 labels for a small area that I no longer need.
nkeeley
Message 5 of 9 (262 Views)
12-17-2013 07:08 AM in reply to: Bill-Ding
Thanks Bill! Contour shading is a useful alternative that I hadn't tried yet. Helps get closer...
nkeeley
Message 6 of 9 (261 Views)
12-17-2013 07:09 AM in reply to: blair
Those are max/min for the entire part. I'd like the max/min of a smaller user defined area. Thanks for the response!
nkeeley
Message 7 of 9 (258 Views)
12-17-2013 07:11 AM in reply to: drguitarum2005
drguitarum. That would definitely help if it had been kept :smileytongue: But I do know that you can delete probe labels. For some reason they are pretty tricky to grab though. I find it easier to drag one off into space with nothing behind it then right click and delete. Just makes sure I get the right one. Thanks!
Employee
Bill-Ding
Message 8 of 9 (241 Views)
12-17-2013 06:13 PM in reply to: drguitarum2005
Please find the attached files and have a look. Are there the probe tools which you're finding?
Bill Ding
*Expert Elite*
blair
Message 9 of 9 (236 Views)
12-17-2013 08:57 PM in reply to: Bill-Ding
It appears the poster is looking for a filter tool to locate the Min or Max areas within a defined area or a part within an assembly.
Win7-64
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
