Inventor General
Distinguished Contributor
brian.cranston
Message 11 of 17 (581 Views)
Re: Inventor Drawings to AutoCAD
08-09-2011 01:19 PM in reply to: hoaglin14
Each view is a stored as a block for use in AutoCAD.  Open it in Autocad and use the 'Insert' command.  Select the desired view and explode.
-Brian Cranston
hoaglin14
Message 12 of 17 (577 Views)
08-09-2011 01:30 PM in reply to: coreyparks
That worked, thanks
Employee
jeffrey.sun
Message 13 of 17 (546 Views)
08-10-2011 10:09 PM in reply to: hoaglin14
Alternatively, the UNGROUP command can be used to explode the view group.
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Valued Contributor
swimfast831
Message 14 of 17 (527 Views)
08-11-2011 05:45 AM in reply to: jeffrey.sun
We have problems converting section views into autocad
we have inventor 08 and acad mechanical 08
Employee
jeffrey.sun
Message 15 of 17 (518 Views)
08-11-2011 06:55 AM in reply to: swimfast831
What's your exact problem?
Are the section view geometries wrong?
Could you attach the source Inventor idw, generated AutoCAD dwg file and the image snapshot with the problem highlighted?
Jeffrey Sun
SW Engineer
aargear
Message 16 of 17 (471 Views)
08-17-2011 10:08 AM in reply to: hoaglin14
Open as Read Only Inventor DWG file in ACAD (since ~ ACAD 2010  or 2011 ?).
Type  _exportlayout and press <Enter>.
Save & open new (model space) file.
Edit drawing in ACAD (explode or Block editor etc.).
P.S. I use "exportlayout" way only for simple task (drill / end points for CNC). I finish all my drawings in Inventor only.
WBR
Andrey
New Member
gcamacho23
Message 17 of 17 (319 Views)
05-01-2013 03:01 PM in reply to: hoaglin14
exporting inventor drawing into a dxf and opening the dxf file in autocad worked. I dont see why saving as a dwg wouldnt work.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
