Hi All,
We're attempting to setup our drawings so that they conform to BS 8888:2011 but have hit a bit of a snag.
Namely, we know we can set the regional settings (coupled with the styles library setting) so that the decimal separator in Inventor becomes "," instead of the default "." as per section 22.3.2:
This works great for most dimensions, except those that we pull through from parameters.
Is there a registry setting specific to Inventor that can force this change for us? If not, is there anything that can be done with iLogic/the .NET API?
Alex.
Solved by AlexFielder. Go to Solution.
Well, I've been able to recreate what you're asking, but I haven't found any workaround yet. I'm posting this mainly to bump your question. Might also try posting in the Inventor Customization forum, maybe some of the programming gurus in there would have ideas.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
