Inventor General
Johnnyjack777
Message 1 of 4 (276 Views)
Inventor Drawing .DWG outputs broken files
276 Views, 3 Replies
02-27-2012 12:06 PM
The basic save, when making an inventor drawing....
Produces a file that is a Black Panel, to Every other program than inventor... (Tried 5 so far, some just fail to open)
REALLY basic thing that is failing... is it really a proprietary file they "called" .dwg?
Or is there some setting I have on?
Either way, thanks for your time,
-Johnny
Best way to show this is open this file in Solidworks.
Employee
jeffrey.sun
Message 2 of 4 (258 Views)
Re: Inventor Drawing .DWG outputs broken files
02-27-2012 05:39 PM in reply to: Johnnyjack777
I tried your attached dwg with AutoCAD 2012, AutoCAD Mechanical 2012 and DWG TrueView 2012. The two views can be shown correctly.
Which programs have you tried?
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Johnnyjack777
Message 3 of 4 (247 Views)
02-27-2012 08:53 PM in reply to: jeffrey.sun
Irritating... you have to Save as.... save as COPY.... to get the correct formats... they are NOT in export.
I tried Solidworks, Partworks, alibre/libre? Coreldraw.... pretty much all Non-Autodesk products (Whatever was on the computer I was using ; )
(Also, Come-On!  DWG true view is included WITH inventor, and Audocad/Autocad mechanical are basically the same program too...  Yes inventor opens the file inventor created :smileyhappy:
Employee
jeffrey.sun
Message 4 of 4 (237 Views)
02-27-2012 09:25 PM in reply to: Johnnyjack777
Have you tried to save copy as "AutoCAD DWG File (*dwg)"?
Note: The result dwg of the types "AutoCAD DWG File (*dwg)" and "Inventor Drawing File (*.dwg)" are different. In the Save Copy As dialog, the two types are both listed in the "Save as type" combobox.
Jeffrey Sun
SW Engineer
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
