Hi Guys,
I have an inventor DWG saved that is a single sheet with 4 views of a standard piece of equipment we like to layout in ACAD factory layout DWG files.
When I open the Inventor DWG there is nothing in Modelspace, but the Paperspace sheet shows the correct 4 views. Thats fine.
So I go into MSpace and insert the INV created 4 blocks that make up the views on the PS sheet. No problem they are all there, now i have an INV DWG file I can use as a basis for everyone else to get the blocks into another seperate ACAD factory layout file.
***HOWEVER***
Thinking I want these factory layouts to update if the Inventor DWG does, I xref the INV DWG file into the factory layout, which shows the 4 views in Mspace. What If I only want the plan view? I cant seem to then access the individual blocks within the xref in ACAD? You get the entire Mspace only?
Is there a different way to attach xrefs that allows me to select only a certain block?
I know I can use Design Center to copy the blocks into the factory layout one at a time. But it would be nice to have them xreffed so a change to the machinery in the Inventor DWG is pushed to the ACAD factory layouts....
Is there a different workflow to do this other than having a seperate Inventor DWG file for each elevation?
Ta
Brian
Design Center allows you to update the blocks. I cant remember if it prompts you theres an update pending though. Maybe theres a system setting to push the updates on file open.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
