Inventor General
*Expert Elite*
blair
Message 11 of 19 (250 Views)
Re: Inventor Crashes when loading any file, or closing welcoming center
01-19-2013 09:25 PM in reply to: terpsurfer
Not really sure why you are having the installation problems that you are. Along with JD's recommendations, make sure that you have Administrative Privildges as well as having the UAC turned off (slider set to lowest setting) and your A/Virus software disabled just for the Installation. Some A/V software will stop certain edits to the Windows Registry. Make sure your .NET is at 4.0
I would make sure that you are current on all Windows SP's and hotfixes for your O/S and current graphics card drivers.
I would use the Autodesk Clean Un-Install to remove all traces of the old install prior to trying to re-install the software.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
*Pro
sbixler
Message 12 of 19 (231 Views)
01-20-2013 04:43 PM in reply to: blair
Stuff like this can result from a corruption somewhere in your user profile.  Try starting Inventor from a different login (with power user privileges or better).  If this works, then delete every bit of anything related to Inventor from your profile and try again.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Active Member
Message 13 of 19 (223 Views)
01-20-2013 08:40 PM in reply to: sbixler
.net Framework is @ 4
uac has been turned off
vista sp1 & 2 have been installed
I'm currently working on the graphics drivers and should have it finished soon. I'm able to run revit 2012 so i'm not sure why its a problem, anyways..
I will turn off my a/v during the install and I hope it works! Thanks for all the help!
Active Member
Message 14 of 19 (203 Views)
01-21-2013 02:31 PM in reply to: terpsurfer
Same exact problem with ALL of these issues addressed. I'm fed up and pissed. Can someone pless point me in the direction of a customer support rep?
*Expert Elite*
DarrenP
Message 15 of 19 (196 Views)
01-21-2013 02:34 PM in reply to: terpsurfer
all support is through the reseller channel
http://usa.autodesk.com/adsk/servlet/ps/searchform?id=1088201&siteID=123112
FYI vista is not a supported OS anymore with any 2013 products
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18424371
it also could be your computer can't handle inventor 2013
Active Member
Message 16 of 19 (178 Views)
01-21-2013 05:15 PM in reply to: DarrenP
Alright, so what If I were to try inventor 2012?
Active Member
Message 17 of 19 (173 Views)
01-21-2013 06:29 PM in reply to: terpsurfer
Attempted to install the 2012 version and to my surprise I found this!
I'm now going to attempt to install AutoCAD_Architecture
*Expert Elite*
blair
Message 18 of 19 (161 Views)
01-21-2013 11:03 PM in reply to: blair
Check in the primary folder for the installation (where the setup.exe file resides), there should be a "readme" file.
Win7-64
*Expert Elite*
Message 19 of 19 (134 Views)
01-23-2013 07:51 AM in reply to: terpsurfer
A 6 or 7 year old computer?
When was the last time the HDD was reformatted and OS re-installed (a lot of garbage can build up over several years).
I was running an old computer (about the same specs as yours) and it was getting slower and slower and I had trouble installing Autodesk Simulation.  New install of the original OS and it worked better than it had in years.
Where are you getting the 2012 software (student download?)?
As noted above this is a free peer-to-peer user support group, not the Autodesk support.
Support is through your VAR (Value Added Reseller).
There is also peer support here and often Autodesk Employees chime in, but provide all information
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
