Hello!
Since i get around with the content center i am making our own custom frames and parts.
Now i have made a new category in the structural shapes catergory with all our own standards. Beacuse we're using some of the standard DIN EN 10210-2 pipes i want to copy this library to our own category and remove some of the pipes we never use.
What i did is:
-save copy as the family.
-move to my own library view
- tried to drag and drop the copied part to our own library (not possible)
- tried to change the family properties (parameter mapping) "Structural Shapes->Round Tubes" (not possible)
Is there any way to change the category, move/copy it to the our own category and delete the old one, of this copied library part , so it is easy reachable in the frame generator or "place from content center"?
Thanks in advance!
Paul,
Have you done a search on these forums on this topic? I know I was involved in a thread that was very similar to what youare asking a few weeks back.
I know you can copy and then delete, but try and find that thread and see if that helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi Cadmanto,
the only thread i can see, which can be similair is http://forums.autodesk.com/t5/Inventor-General/change-content-center-category/m-p/3528842/highlight/...
Your last reaction there is:
07-06-2012 06:50 AM in reply to: warrentdo
Warren,
I did a little digging. You are right the drag and drop does not work and I appologize fort suggesting it.
What I have discovered is that the library view needs to be on the correct folder you are working in.
So far what I have found that appears to work (all be it a little clumbersome) is you can RC on the
file in the CC editor and copy it to the desired location and then delete it from the original.
http://forums.autodesk.com/t5/Autodesk-Inventor/Custom-Content-Center-Update-and-Delete/td-p/2908644
Generally in here RC means right click with the mouse. We wrongly assume everyone understands our abbreviations. And, yes... CC is Content Center.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
See attatched image, I hope this makes more clear what i would like to do with my copied and modified library part
Sadly, after right click, there is no "copy to other category" option, or something like that.
Sadly, the fact is that as of now, that functionality doesn't exist. It has been added to the idea station,... probably more than once. Perhaps in a future release. Was this family published from a custom i-part, or was it simply a copied existing CC family? Depending on how it was done, there are different ways you can proceed.
Chris Benner
Hi, thanks for putting this option in idea station!
This is a copy-paste from a content centre file. I could have used the option to publish an ipart, but now i have all properties, name-tags and more without putting a lot of energy in it. So it would be nice to go ahead with this file in stead of an ipart.
This is actually the thread I was talking about.
Chris is right when he said that "RC" means "Right Click". There are a lot of short cut terms you will grow to learn if you stick on these forums.
Let me know if this thread helps you. Like it has been mentioned, there may not be a solution just yet, but I know there is an idea postesd in this thread link you might want to check out. As well as searching for others.
Well, I see two options. I'm not very familiar with authoring structural shapes, but I bet you could find some tips on that in the wiki help. I may be wrong, but I'm thinking that as long as your custom folder is in the structural grouping (it looks like it is), you could author the shape choosing that as the Category. (caveat... I've never tried this). Once it was authored with that as the category it should publish to that folder. To try this, youwould need to "Open from Content Center", select any instance from the family table and open it "As Custom". Then Re-Author it... like I said, I don't know for sure this will work.
The other thing you could do, if you never ever use certain sizes of this profile, is just edit the family table in it's base category, and remove the ones you don't use. You would have to save the family to your read / write library first, but it looks like you did that already.
btw... please forgive my atrocious typing, I am fat fingered this morning!
Chris Benner
