Searching these forums forums & the web, I've found things like:
Dim odoc As Document
Dim ocompdef As ComponentDefinition
odoc = ThisApplication.ActiveDocument
ocompdef = odoc.ComponentDefinition
And
ActiveSheet.View("VIEW1").ScaleString
ActiveSheet.View("VIEW1").View.Suppressed
I'm wondering, is there a list available detailing the content of the Inventor 2013 API and a list for the iLogic properties of objects? Preferably with some sort of description what they do.
Thanks!
Solved by mrattray. Go to Solution.
Solved by alewer. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi MetalH34d,
You can refer to the API Help Reference. It can be accessed by the flyouts shown in this image.
I hope this helps.
Curtis
(Thanks to sbixler for the screen shot)
It sounds like you're looking for the object model. If you've installed the developer tools, you can find a .pdf object model in the ...\SDK\Docs folder. Go to http://www.autodesk.com/developinventor (begin reading at the Inventor SDK heading) for better directions. Good luck!
