Inventor Forum
Inventor 6 graphics slowdown
11 REPLIES 11
Message 1 of 12
391 Views, 11 Replies
I have an Oxygen GVX1 Pro video card. I was happy with the performance of Inv 5.3. When I upgraded to Inv 6, I noticed immediately that the zoom-window command had developed a severe case of sluggishness. That is, the cursor and crosshairs lag behind mouse movement. Anybody else have this problem, with any video card? (Other commands also exhibit this sluggishness, but zoom-window is the worst.)
I have the latest 'certified' driver installed (849). A second machine with a VX1-16 card acts exactly the same way.
I have been through most of the threads at this location, but I don't see much related to this topic. Anybody know if SP1 addresses this issue? What reference I see to it would indicate that it does not.
By the way, I know that power users of Inventor probably don't even bother with the zoom-window button, but after 12 years of AutoCAD, it will probably be my tool of choice (old-dog/new-trick syndrome).
11 REPLIES 11
Message 2 of 12
Tim,
    With a part/assy/drawing open,
do a Tools>Application Options, then click the Hardware tab, then click the
Diagnostics button.  If you see anything like "Microsoft Generic" or
"Software OpenGL" then your card is not being used in accelerated mode.
The only fix I found was to go to the registry and delete the key:
size=2>HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion6.0
    Make sure to back up the
registry first and that IV is closed before you do this.  Restarting
IV will recreate the key and (in our cases) give you the
acceleration.
HTH, Alan
I
the worst.)
syndrome).
Message 3 of 12
Yes. We have a couple of Quadro4 900XGL cards and
they are running awful. When we sketch in a .ipt the yellow dot lags behind the
crosshair a great deal. Hopefully this will be addressed whenever the first
Service Pack is released.
I
the worst.)
syndrome).
Message 4 of 12
We use the Quadro4 500GoGL cards in our laptops and
we found that changing the Hardware settings in IV to "Over-ride Settings to
Full Optimization" helped performance.
Mike
Gauvin
INCAT-Arizona
the crosshair a great deal. Hopefully this will be addressed whenever the
first Service Pack is released.
I
syndrome).
Message 5 of 12
Tried that and didn't notice any gain
whatsoever.
and we found that changing the Hardware settings in IV to "Over-ride Settings
to Full Optimization" helped performance.
Mike
Gauvin
INCAT-Arizona
and they are running awful. When we sketch in a .ipt the yellow dot lags
behind the crosshair a great deal. Hopefully this will be addressed whenever
the first Service Pack is released.
I
syndrome).
Message 6 of 12
I checked this, and the diagnostics say I am using a "graphics driver certified with limitations", but that I am "using full optimization". I tried your suggestion anyway, and no change was noticed. (Incidentally, prior to installing the card under 5.3, I had already updated the registry with the keys from the AutoCAD site.)
Message 7 of 12
I might try this, although the diagnostic says I am "using full optimization". I guess it can't hurt to try it.
Message 8 of 12
There are some know issues that you will not be
able to work around. these issues have been addressed in the service
pack.
-Kevin Schneider
I
the worst.)
syndrome).
Message 9 of 12
imgur
Hello all.
Yes, all of our designers noticed performance
slowdown especially in Zoom Window and everything
behind the mouse movement, high CPU utilization...
after we upgraded to Inventor 6.
Will SP1 fix the problem? don't think so, what likely
will be the next step is to upgrade all of our systems,
Hope I am wrong, waiting for SP1...
Our setup is AMD Thunderbird 900
1Gig of memory, 3DLabs GVX1 video,
Win2K pro Sp2, Inventor 6, we also
have Tyan dual Athlon MP 1700 which
was very stable but now a bit slower
since introduction of Inventor 6.
Message 10 of 12
Well, I installed SP1 on the home machine with the VX1-16 card. There was no noticable change in mouse behavior. On Monday, I will try it on the office machine with the GVX1 Pro card, but I don't expect much. The readme for SP1 contained no reference to this condition.
Tim Eaves
Message 11 of 12
See my reply to Inc./Autodesk, above. SP1 had no affect on one machine, will have to wait until Monday to check out the second machine, with the GVX1 Pro card.
Tim Eaves
Message 12 of 12
I finally got to try SP1 on my work computer with the GVX1 Pro and more system memory. There might be a little improvement from before SP1, but there is still a significant lag from 5.3.
-Tim Eaves
