Inventor General
New Member
Message 1 of 4 (88 Views)
Inventor 5 wont open!!!
88 Views, 3 Replies
12-02-2006 11:07 AM
So i recently tried to load Inventor 5 onto my home computer. The installation went fine, but now the welcome image opens (a spaceship) for a couple seconds, disappears, and then nothing else happens. any help would be great!
*Duncan Anderson
Message 2 of 4 (88 Views)
Re: Inventor 5 wont open!!!
12-04-2006 04:31 AM in reply to: mattman_83
It's a very deep sub-mersible
Inv should go to the Activation/Registration screen after the initial splash screen.
Did you disable your anti-virus when installing ?
Do you have Flash8(a) installed - remove using the utility from
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_14157
And then install Flash9 http://www.adobe.com/go/getflashplayer
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by
fabricated insanity that nothing could be as mad as what passes for ordinary
living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
wrote in message news:5412885@discussion.autodesk.com...
*Joe Howard
Message 3 of 4 (88 Views)
12-04-2006 05:09 AM in reply to: mattman_83
Do you have Excell on your home machine? it is required for inventor and if
just installed excell you must open excell at least once to activate it.
be great!
*Gary R Smith \(Autodesk\)
Message 4 of 4 (88 Views)
12-04-2006 06:45 AM in reply to: mattman_83
You might also make sure that your home machine has a graphics card/drivers
that supported INV5
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
