When attempting to open multiple files at once from inside Inventor 2015 the software locks up and goes into "Not Responding" mode. It never comes out of that mode and we have to use the Task Manager to kill the process and start Inventor again. The same thing happens when we try to "Place" multiple components (at one time) into an Assembly. Anyone seen this before??
Mark,
As far as I know you can only open one file at a time from within Inventor. I know you can have multiple fiules opened at once if that is trully what you are talking about.
How many files do you have open at once before this happens? How large are the files? What are your system specs?
I know when I used to use 2012 if I had too many large files open it would lock up and act weird.
Does this do what you are seeing after a fresh restart of your machine?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi Scott,
Thanks for the reply. Yes, you can open multiple files at once from inside Inventor. Select open, drag a window around some files or use control/shift to select multiple files and then hit open and each will open in their own window. This has been around for a while and is still the case. On some of our machines we have no problem with this (Inventor 2012, 2013, 2014, and 2015). On a few however Inventor 2015 locks up. It doesn't matter if there are other files already open or not. Also, it doesn't matter if you restart the machine or not. And we have uninstalled (clean uninstall) and installed Inventor from scratch but this did not help either.
The machine is up to spec. W7-64, 16GB RAM, 4GB NVIDIA Certified card.
As a test I opened about 20 iam's, ipt's and dwg's in less than 45 seconds.
They we all fairly simple parts / assemblies
IV 2015 Update1
Thanks rdyson. That is the expected behavior and what happens on some of our machines but not all.
and what if you log into these machines that don't work as a different user?
We tried that first. We logged on as the default Administrator account. No change. Cleanly uninstalled Inventor 2015, rebooted, created a new user account, installed Inventor 2015, rebooted, tested again, same results. Still locking up. Opened Inventor 2014, it responds as it should by opening and placing multiple files as called upon.
run a memtest?
(just throwing out ideas...)
Hi! Could you be more specific on "multiple'? Is it two or three or a hundred?
Thanks!
The behavior does not seem right to me. Did you try selecting two Inventor files in File Explorer and drag&drop them to Inventor? Does it work?
Thanks!
Hi Mark,
As Johnson stated this is not correct - I just opened 150 files in a single open operation. Have you looked at event viewer to see if there is anything of use there ?
What do you have your Inventor temp file location & undo size set to ? (App Options, General & File tabs.) Have you emptied the %temp% folder ?
Have you tried disabling anti-virus & MyHome ? Clutching at straws a bit here, since we don't usually have any issues with this....
Chris
Hi Mark,
I don't know that we've ever test Sager latops - which models do you have ? Which graphics mode in Inventor are you using ? Does it make a difference if you change to "Conservative" or software graphcis before opening ?
Do you have hyper-threading enabled at the BIOS level? What if you disable that ?
Also as a test, start Inventor & then go to Task Manager & find the Inventor.exe process, Rt click it & got to Set affinity - change the CPU affinity so that it only runs on a single CPU core - then try opeing the files - any change ?
Chris
