Hi - I am really struggling to find all my icons after going from IV 2014 to 2015. It seems there are 10 icons where there should be 25! Any ideas?
Solved by Curtis_Waguespack. Go to Solution.
Tools\Customize.
You've always had the option of setting up the UI any way it works best for you. I think the developers got so many suggestions that they tried to make everyone happy.... which can never happen of course.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@cbenner wrote:
Tools\Customize.
Yet they STILL keep trying year after year..
@dalibu wrote:
... Any ideas?
Hi dalibu,
You can right click any tool group that has a dropdown arrow next to it and choose Ungroup. And you can also select a specific tool and choose Move to Main Panel if it's one you use often.
Those suggestions might ot might not help you, but they are options to be aware of:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-E5AB014C-D87B-4D7B-963C-00847E3DDE01
I hope this helps.
Curtis
