Solved by pdxmcad. Go to Solution.
Ryan,
Looking at the crash reports you sent in this morning, it appears that you have an old beta version of the 2014 A360 installed on your system and that's what is causing the crash.
If you un-install the old A360 and then re-install it from your 2015 install the crash should go away.
