Hi all.
I'm trying to output a drawing to opening in Autocad. I'm using Inventor 2014 and Autocad 2010. I have tired to 'back-date' the Inventore DWG file Version but when i open the cad file it come up with 'The drawing cannot be open becuase it was created with a later version etc. I have attached screen shot, what have i done wrong?
Many thanks.
Solved by sam_m. Go to Solution.
If you do "Save as" -> "Save Copy As" and select dwg, what is displayed in the options box?
It might be worth trying dxf (2000 version), to see if helps...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Worked!
It was set on AutoCAD 2013, changed it to Autocad 2010 and it worked fine.
Thanks sam_m.
good to hear mate,
please mark the problem solved (click on "accept as solution" in bottom-right of the relevant post), so people scanning the forum can see this issue is resolved.
Thanks, Sam
Sam M.
