SP1 made Inventor able to start on windows 8.1, but saving drawings in AutoCAD format is impossible. The "options" button does nothing and the "OK" button pressing results inevitably in a "Problems encountered while saving the document" error regardless of the target folder chosen or the file size.
OS: Windows 8.1 x64
Oh.. you expected it to work the first time? ha ha ha ha sucker.
It has been PROVEN that Autodesk can't get anything 100% function the first time around.
Someone over there has been reading too many "continuous improvement" books.
Because all of us *never* make mistakes. Right?
I don't.. I'm perfect
I only make mistakes so people don't catch on that I'm a cyborg.
I must add, that this bug applies not only to AutoCAD DWG export; as a matter of fact NO VECTOR EXPORT is possible from an Inventor 2014 drawing on a Windows 8.1 OS.
Would you be more specific about "NO VECTOR EXPORT is possible"?
Which file formats you are seeing a problem?
I believe I was able to export 2D drawing to PDF, DXF, and DXFx format.
BTW, I posted a possilbe workaround in the following post:
Please try and see if that works for you.
Thank you,
-Sami Harada
Inventor Framework QA
Autodesk, Inc.
They hired ObamaCare programers 🙂
I ran into all sort of issues:
Hopefully Inventor 2020 will fixes the issues 🙂
Environment: Windows 8.1 Ultimate x64, Inventor 2014 Pro, SP1 with Update 1
