Inventor General
New Member
Message 1 of 6 (861 Views)
Inventor 2014 crashes with realistic view
861 Views, 5 Replies
05-08-2013 01:41 AM
Hi everyone
I recently updated to Inventor Professional 2014.
The problem I encounter is that Inventor crashes sometimes when I turn the realistic view mode on.
Is there anyone else who has this problem?
Also the rendering in realistic view mode is much slower than with Inventor 2013.
Are there some ray tracing options that I need to set up?
Kind regards
Nick
Member
Message 2 of 6 (817 Views)
Re: Inventor 2014 crashes with realistic view
05-09-2013 06:47 AM in reply to: nick.jeuris.pvs
Same here! I just upgraded to Product Design Suite Premium 2014 from Factory Design Suite 2013 and cannot render anything. Even on the lowest antialiasing setting. Crashes the program everytime!
Valued Mentor
RayFeiler
Message 3 of 6 (813 Views)
05-09-2013 06:53 AM in reply to: nick.jeuris.pvs
No issues here...yet :smileyindifferent:
Xi® MTower™ PCIe Workstation
Intel® Core™ i7 2700K @ 4.10GHz
16384MB DDR3 @1333MHz Dual Rank Interleave
nVidia® EVGA® GeForce® GTX 580 Classified 3072MB GDDR5
500GB 7200RPM SATA 6.0Gb/s 16MB Cache IntelliSeek™
Asus® P8P67 Motherboard
27" S27A350H ToC Samsung® SyncMaster™ Wide LED 2ms. 1920x1080
850W Corsair® TX Series Power Supply
Microsoft® Windows® 7 Professional Edition 64Bit SP1
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Product Support
Message 4 of 6 (802 Views)
05-09-2013 10:00 AM in reply to: nick.jeuris.pvs
You can use the NFO file to determing the video card and driver version you have installed. More than likely it is old.The system NFO file of that machine Start>All Programs>Accessories>System Tools>System Information. Under components there is Display. Compare that information against the below link.
Verify Hardware certification
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
If your card is not listed then it is not certified. Try getting the manufacturers latest and greatest one for that card.
Don
Member
Message 5 of 6 (799 Views)
05-09-2013 10:46 AM in reply to: nick.jeuris.pvs
I'm running the NVIDIA Quadro 4000 with the latest version 9.18.13.745.
*Expert Elite*
dgorsman
Message 6 of 6 (789 Views)
05-09-2013 11:13 AM in reply to: JStone_629
The rest of your system specs will help eliminate a number of possibilities.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
