Inventor Forum
Inventor 2014 crashes on export
3 REPLIES 3
marcusfriesl
521 Views, 3 Replies
I have a file created in Inventor 2014.  I am trying to export the file as a STEP file, and have tried every other format and combination there of.  Inventor crashes during every export.  Other files work perfectly well.
I just can't get this file to export out.  Any help would be greatly appreciated.
Tags (2)
3 REPLIES 3
CCarreiras
in reply to: marcusfriesl
Hi!
I think you had a issue in your part: The multisolid had 3 solids, but in reallity you had only two, so i redo the last extrusion and selected one of the 2 firsts solids to cut, and that way, the part maintained 2 solids in the final.
Export, and, worked!!!
Part in attach.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
marcusfriesl
in reply to: CCarreiras
Thanks for the quick turnaround!
And thank you for the solution, didn't even think to check that.
Yijiang.Cai
You could have a try when R2014 SP1 is available.
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
