Hi All
I am working with a student version of inventor 2014, how and where do I get the mesh enabler does this version? I have got some 3d scanned objects that I would like to use in my design.
Regards
NJ
Hi NJ,
Welcome to the community,
Inventor does not quite have Mesh modeling like you would find in AutoCAD. What exactly are you trying to do? Maybe we can find a work around. Pictures would be helpful
Can you please send me the file and I could quickly try it and give you a more accurate answer?
If you search here on stl mesh enabler you should find a thread with response by Autodesk employee Scott... well now can't remember his last name, anyhow, you can get his email for obtaining the add-in as a student.
or
simply zip and attach the stl file here and someone will convert it for you.
The original stl file
Theres no attached file. Please attach again. If it gives you an error that you cannot attach the file type. Put it in a zip file and try again
Ugh, I am so frustrated right now. I had a support issue the other day with the same problem and we solved it. I just cant figure out which command it was right now. I phoned my colleague and he is also having a look at it. I am so sorry, Ill try to get it back to you asap.
Please have a look at these links:
http://makibox.com/forum/topic/1642
I will sit with my colleague tomorrow and give you feedback.
Your surfaces do not define a "watertight" volume - therefore it will not solidify.
Ok So as far as I could figure it out. Your Face does not want to convert to a surface, hence it can not be subtracted from the box. (See Attachment)
I would recommend that you take the stl file into Alias and convert the stl file to a surface. then bring the alias file into Inventor and then subtract that file.
I provide the Mesh Enabler to students on a regular basis.
That sounds like a good idea. @Scott - is it something you can download from Autodesk Labs?
The download is not public. This is something I handle on a case by case basis.
Hi everyone, first post! Im using inventor as student for about 2 months now and still learning, so far projects went well but i think im facing the same problem, spent some time making an assembly for a computer pc layout reference but this time i used some stl files instead of making them (see image 1 attached) and everytime i tried exporting or anything i got blank except for the base which i made from an ipt file (image 2 ) , is my problem the same ? and if it is what would be the best way to fix this? thanks!
