Inventor Forum
Inventor 2014 and mesh enabler
20 REPLIES 20
Message 1 of 21
1598 Views, 20 Replies
Hi All
I am working with a student version of inventor 2014, how and where do I get the mesh enabler does this version? I have got some 3d scanned objects that I would like to use in my design.
Regards
NJ
20 REPLIES 20
Message 2 of 21
JoAnn_Hogan
Hi NJ,
Welcome to the community,
Inventor does not quite have Mesh modeling like you would find in AutoCAD. What exactly are you trying to do? Maybe we can find a work around. Pictures would be helpful
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 21
in reply to: JoAnn_Hogan
Dear JoAnn
Thank You for your reply
If I am correct Inventor 2013 did have an enabler for editing, or was that
just for importing a stl file.
Ok what I am trying to do is ..
1)first scan an object
2) Create a larger object using a sketch in Inventor
3) Then using the "DERIVED" feature in inventor to get mould effect of the
scanned object on the drawn object.
For example If first draw a thick square block. Then I was to get a 3D scan
of my hand. I would like the derive feature to create another square block
with my hand prints onto that object.
Bit like a glove to a hand.
I can achieve the derived feature concept if both object are drawn in
inventor but not when one is scanned to an stl.
Please advise me on what I must do.
Thank You
NJ
Message 4 of 21
JoAnn_Hogan
Can you please send me the file and I could quickly try it and give you a more accurate answer?
Jo - Ann
Message 5 of 21
JDMather
If you search here on stl mesh enabler you should find a thread with response by Autodesk employee Scott... well now can't remember his last name, anyhow, you can get his email for obtaining the add-in as a student.
or
simply zip and attach the stl file here and someone will convert it for you.
Message 6 of 21
Dear Jo Ann
Would you like the original stl file or the project file I am working with?
Regards
NJ
Message 7 of 21
JoAnn_Hogan
The original stl file
Jo - Ann
Message 8 of 21
Please find it attached.
Message 9 of 21
JoAnn_Hogan
Theres no attached file. Please attach again. If it gives you an error that you cannot attach the file type. Put it in a zip file and try again
Jo - Ann
Message 10 of 21
Sorry,let me try again
Message 11 of 21
JoAnn_Hogan
Ugh, I am so frustrated right now. I had a support issue the other day with the same problem and we solved it. I just cant figure out which command it was right now. I phoned my colleague and he is also having a look at it. I am so sorry, Ill try to get it back to you asap.
Jo - Ann
Message 12 of 21
JoAnn_Hogan
Please have a look at these links:
http://forums.autodesk.com/t5/Inventor-General/How-to-use-stl-and-other-mesh-files-in-Inventor/td-p/...
http://makibox.com/forum/topic/1642
I will sit with my colleague tomorrow and give you feedback.
Jo - Ann
Message 13 of 21
JDMather
Your surfaces do not define a "watertight" volume - therefore it will not solidify.
Message 14 of 21
JoAnn_Hogan
in reply to: JDMather
Ok So as far as I could figure it out. Your Face does not want to convert to a surface, hence it can not be subtracted from the box. (See Attachment)
I would recommend that you take the stl file into Alias and convert the stl file to a surface. then bring the alias file into Inventor and then subtract that file.
Jo - Ann
Message 15 of 21
I will give that a go. Is that Alias Design software?
Message 16 of 21
scott.sheppard
I provide the Mesh Enabler to students on a regular basis.
Scott Sheppard
Program Manager
Autodesk Labs
Message 17 of 21
That sounds like a good idea. @Scott - is it something you can download from Autodesk Labs?
Jo - Ann
Message 18 of 21
The download is not public. This is something I handle on a case by case basis.
Scott Sheppard
Program Manager
Autodesk Labs
Message 19 of 21
in reply to: scott.sheppard
I think you have sent me a download link
I will give the enabler a go over the weekend and post my experience.
NJ
Message 20 of 21
Hi everyone, first post! Im using inventor as student for about 2 months now and still learning, so far projects went well but i think im facing the same problem, spent some time making an assembly for a computer pc layout reference but this time  i used some stl files instead of making them (see image 1 attached) and everytime i tried exporting or anything i got blank except for the base which i made from an ipt file (image 2 ) , is  my problem the same ? and if it is what would be the best way to fix this? thanks!
