For next releases:
1 - Editing sketches dimension just clicking on feature, like SW.
2 - Show the entities information without having to search for the information, like SW
3 - Ability to insert constraint just selecting the entities and software knows what you want, like SW.
4 - Change the view drawing even after inserted on sheet, is very usefull. Ex: You inserted a front view but you want to change it to top view. So you must delete the view and choose another one.
5 - Width mating parts.. it MUST have on assembly environment.
6 - Improve or complete change the 3D sketch. SW have one of the best, simple and full controlled 3d sketches of ever. Please, call them and ask how they do it.
Well, this is just a lew wish list.
Marcos Fenerichi
Ullian Sheet Metal Doors and Windows - Brazil
Inventor Professional 2013 SP 1.1 - 64-bit
Dell Precision T3500
Solved by Curtis_Waguespack. Go to Solution.
Just so you know there is a thread with quite a few wishes already.
HI fenerichi,
The best place to post wish list items these days is the Inventor IdeaStation.
I hope this helps.
Curtis
and you may as well start or go with a 2015 wish list as I am sure 2014 is not going to be changed or added to at this point.
In regards to this one, Inventor is way past this-- before about 2011, double clicking on a feature would show all sketches and other dimensions associated with the feature, available for editing. Now you just use the right mouse button and choose "Show Dimensions". Change dimensions as you wish, then hit the 'Update' button. Still very useful, just not quite as easy to get to as it used to be.
