Inventor General
*Expert Elite*
Message 71 of 138 (1,449 Views)
Re: Inventor 2014 Wish List?
10-15-2012 12:06 PM in reply to: buffs_star
buffs_star wrote:
I've just installed 2013 and was hoping for a few of my issues to be fixed.. Silly me..
Anyhow my wishlist for 2014 is mostly to do with the 2d drawing environment which I think could do with a bit of work. :
I suspect that anything that will be in 2014 is already set in stone http://www.beta.autodesk.com
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Distinguished Contributor
Message 72 of 138 (1,413 Views)
10-16-2012 12:17 AM in reply to: FProcp
What I wish for is a hole template. At our company we mill holes with grooves in it. So first we mill/drill the hole, and after that we use a profiled-mill to mill two grooves in it. This hole can recur several times in one part. It would be nice to save this hole-type in a template and recall it the same way as with punches in sheetmetal; by a sketch with centermarks.
Product Design Suite 2014
Inventor 2014, Vault 2014
HP Workstation Z220
Intel Xeon 3.4GHz
16GB RAM
Nvidia Quadro 4000
Windows 7 Professional (64bit)
Message 73 of 138 (1,407 Views)
10-16-2012 12:21 AM in reply to: RyanBotha
That's a good one! Also with triangular patterns!
HP Workstation Z220
Intel Xeon 3.4GHz
16GB RAM
Nvidia Quadro 4000
*Pro
sbixler
Message 74 of 138 (1,396 Views)
10-16-2012 04:28 AM in reply to: miechh
Wouldn't iFeatures accomplish most of what you want?  And I believe that the punch tool would do this, too.  JD will have to give you more detail, or you could search the forum for this-- he has proposed punches as a solution to many such questions.
Valued Contributor
Message 75 of 138 (1,309 Views)
10-24-2012 11:18 PM in reply to: FProcp
I really like the idea of Solidworks 2013 CAD Administrator Dashboard.
I would like toolpalettes the same way AutoCAD has them, where I can have standard content in a central location, giving me the ability to update the content at any time, and change the toolpalette at any time to keep it current.
I hate having to load up a drawing template with all the content an Inventor user might need, and to have all that additional data bulk up each drawing that gets created, which just sits there and does nothing other than become outdated eventually.
I want to be able to add presets for features (hole features for example, we never ever make 2mm holes 8mm deep) to a network based style library, to give users settings they would need 90% of the time.
And talking of style libraries, this does not work well in a Vaulted environment where laptop users need their style library available locally. Maintaining this through Vault is a painful process, and with each change I need to notify the users to update their style library files? Make the style library some mystical database type library; me the Administrator makes a change, gets applied to Vault (similar to updates done to Content Centre?), and a connected Vault user will magically get the latest style library cached somewhere on his/her local machine.
Same deal with templates btw, let me manage those in Vault, and have Vault cache it locally, all by itself (without a user having to click through 10 messages warning the user of all sorts of things they don't understand).
Oh, and has anyone ever figured out how the network administrator can control the list of permissable service packs using Communication Centre, and make it available to users once the admin has tested/approved it? I tried once and gave up.
Active Contributor
AdrianT
Message 76 of 138 (1,304 Views)
10-25-2012 01:23 AM in reply to: FProcp
Wish list -> in the sketch mode, the ability to draw rectangles with rounded ends, as for the slots for the sole plates of bearings etc.
And:
A browser bar that doesn't only run in one direction down, so in other words, it should follow on sideways with more information because sometimes the brower can get a little busy with a derived part, several surfaces, sketches you want to hide/unhide etc. I use two screens and the second screen always has my browser bar on it, amongst other things. Observe the screenshot, it's annoying to have to scroll up and down through the brower. Whereas if it had the ability to get wider with info flowing into a 2nd and 3rd column that would be ideal.
Valued Contributor
machiel.veldkamp
Message 77 of 138 (1,300 Views)
10-25-2012 01:47 AM in reply to: FProcp
I wish a batch export from .idw/.dwg to PDF from folder X to folder Y function in Task Scheduler.
___________________________
Inventor 2012 lastest service pack
RAM: 24GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
Video: NVidia GeForce 680/ HDD: 15.7K
Windows 7 Pro 64-bit
Anthony
Message 78 of 138 (1,296 Views)
10-25-2012 01:54 AM in reply to: machiel.veldkamp
The text editor needs some serious improvement - compared to AutoCADs text editor it is very limited and often awkward to use.
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Message 79 of 138 (1,269 Views)
10-25-2012 05:43 AM in reply to: FProcp
Another wish:
Fill a predefined area (circular/rectangular) with maximum amount of holes in a custom defined pattern (rectangular/triangular--> pitch and angle), and use these predefined patterns to place other parts in this pattern (like "use pattern" in pattern components).
HP Workstation Z220
Intel Xeon 3.4GHz
16GB RAM
Nvidia Quadro 4000
Valued Contributor
RyanBotha
Message 80 of 138 (1,255 Views)
iMates & Component Patterns in Drawings
10-25-2012 07:04 AM in reply to: miechh
Since I'm utilising these area now:
Edit iMates easily, even once the composite is created.
More importantly, the ability to turn visibility of Component Patterns off in drawing environment, rather than selecting even instance. Actually, better selecting of component patterns all round. You cannot select CP in the browser tree in drawing environ...
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
