Inventor General
*Pro
jletcher
Message 51 of 138 (825 Views)
Re: Inventor 2014 Wish List?
09-21-2012 10:01 AM in reply to: mrattray
Again just make Inventor work like it did back in the day.
I think if we put our wishes on the back burner this can happen but if we all keep wishing for more features you are also wishing for a buggy Inventor Like now.
As you can see with all the new things in 2013 you also got more bugs.....
Please just post FIX INVENTOR then we can wish for features..
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
mrattray
Message 52 of 138 (822 Views)
09-21-2012 10:18 AM in reply to: jletcher
I would be 100% happy if they did that. But, I'm not betting on it. They need things to market with. As far as AD marketing is concerned, IV is already the pinnacle of perfection. To admit otherwise would bring their whole world collapsing down on them. So, if AD is going to add more features they might as well be ones that are actually usefull, instead of more iCloud BS.
Mike (not Matt) Rattray
*Pro
jletcher
Message 53 of 138 (820 Views)
09-21-2012 10:22 AM in reply to: mrattray
Guess you don't know why they are going to the cloud...
I will give you a little heads up soon you will not have to load Inventor you will go to the cloud to use it no more local Inventor.....
James Letcher
mrattray
Message 54 of 138 (818 Views)
09-21-2012 10:25 AM in reply to: jletcher
Yeah I know about their crack pipe in the clouds plan... [eye roll]
dan_inv09
Message 55 of 138 (802 Views)
09-21-2012 12:10 PM in reply to: RyanBotha
I'm not sure what all of these are but I figured it'd be better to go through them all then to cut out one or two, the hole note one is the one that prompted me to reply
  • Dragging leader with Part Priority on does not snap to part edge
  • Being able to dimension break view line
But if it's in a sketch like a section view line - I don't know if they've figured out how to fix sketches in break views yet
  • Different detail view shapes, that can be dimensioned to part sketches, or even use part sketches
Yes, definitely
  • Automated centrelines on only certain parts in a view
not sure how that would work
  • Window multiselect CL to resize them together
What, kind of like aligning balloons of something?
  • Auto CL does not recognize derived parts, i.e. iParts (flanges)
Oh, you do not want to get me started on detailing derived parts and iParts
  • Tangent edges on selected parts only
like they did for hidden, yes
  • Lock dimensions that are aligned
 is that when you drag some dimensions the ones that were aligned aren't when you're done?
  • Snap radius dims to other radius dims
I don't know what you mean, would this be something like needing multiple leaders on a radius dim?
  • Dimension to a sketch symbol
is this like not making models for stickers and nameplates?
  • Use part properties and values in sketch symbols
somebody said they could do something like this, but have you tried "Override Shape" to use your sketched symbol as a balloon?
  • Align sketch symbols with better grip control
is this just the extra click because it can't intuitively switch connection points?
  • When copy/paste symbols, I don’t want to deselect the view first
(most of my symbols are for the whole drawing, I don't need to copy symbols attached to views so I've never seen that)
  • Link part parameters in the Hole Notes, i.e. PCD
when you right click, in addition to "Edit Hole Note" there is "Text" which brings up the regular text dialog where you can do all that. It would be very nice if you didn't have to leave the hole note dialog to get to it - it would be best if the hole note was in a regular text dialog with the hole stuff (tap, c'bore etc.) available like they did with the view labels etc.
  • Add Vertex to leader to open space (i.e., not model edge)
are you pointing at nothing or would it be even better if leaders would recognize a part without going to an edge?
  • When editing leader text / normal text, centre the text in the editing window
this is just sloppy implementation of the text dialog, it falls into the category of "ain't never worked but close enough that they will never never ever consider fixing it" that some of us were trying to steer this thread towards near the beginning
dan_inv09
Message 56 of 138 (799 Views)
09-21-2012 12:15 PM in reply to: mrattray
I think they want neither point to be the center.
dan_inv09
Message 57 of 138 (802 Views)
09-21-2012 12:22 PM in reply to: mrattray
I was thinking if you could make a part then put it in an assembly (by itself) and bend it one way and another assembly with it bent the other way instead of having to derive then you would have the flat part and all it's properties available.
mrattray
Message 58 of 138 (744 Views)
09-24-2012 04:50 AM in reply to: dan_inv09
Then wouldn't that be a three point circle?
Distinguished Contributor
kstate92
Message 59 of 138 (740 Views)
09-24-2012 05:29 AM in reply to: mrattray
I think they mean like in AutoCAD (the name that not must be spoken):
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
mrattray
Message 60 of 138 (736 Views)
09-24-2012 05:34 AM in reply to: kstate92
Ah, forgot about that one. I don't think I ever even used it in ACAD, center radius and three point were always good for me. Why would he need it in Inventor I wonder...
I thought it was the, uh, non-liquid-that-doesn't-work that is the one that must not be named...
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
