Inventor General
trumpy81
Message 11 of 138 (2,457 Views)
Re: Inventor 2014 Wish List?
06-15-2012 02:15 AM in reply to: FProcp
No, No, No, ya got it wrong ... They dont start work 'till 10am, then they're off to the pub at 12 .... poor buggers just don't have enough time ... :smileyvery-happy:
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Distinguished Contributor
Anthony
Message 12 of 138 (2,425 Views)
06-15-2012 08:19 AM in reply to: FProcp
One item that is a must for the next version of Inventor is a COPY WITH BASE POINT and OFFSET WITH SPECIFIC DISTANCE IN X, Y or Z commands like what has been available in AutoCAD for years. Not sure how other users feel about this but I have found that using mirror components or pattern etc. can sometimes be over complex and take a lot of time and sometimes does not product the quick results desired whereas to be able to simply select the items and copy them to a specific location would good (under some circumstances). Maybe something like COPY COMPONENTS WITH BASE POINT with a check box to ADD DISTANCE and DIRECTION ? I know there will be people who would disagree because of the issue with retaining constraints, maybe the COPY WITH BASE POINT could be intelligent enough to understand where the constraints are and retain them on the copy. Just a thought for Autodesk.
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
trumpy81
Message 13 of 138 (2,405 Views)
06-15-2012 01:45 PM in reply to: Anthony
Anthony, that's not a bad suggestion, but the problems with constraints will most likely kill it. 2013 has a problem retaining constraints, especially in older parts, so unless that is fixed first your co-ordinate copy probably wouldn't.
In all honesty, I would really like to see Autodesk ignore the marketers for the next release. Autodesk has already established a good product in Inventor and it has a large and mostly loyal group of supporters that will keep the bean counters happy while they fix the little annoyances that ALL users experience with Inventor.
The next release would truly be a new product even without any new features, if all the existing features worked as the designers intended. Along the way, I'm sure some of the requested features could be added but that should not be a priority.
If Autodesk are to continue making money from Inventor then it is just as important for them to get it right and with a bug free base, they could do just that and more.
The more lemons you sell, the less likely you are to have return customers. It's all connected and it all has an impact.
I just hope that the management at Autodesk have the foresight to deal with these issues now, instead of when it's too late.
Regards
Andy M
Message 14 of 138 (2,394 Views)
06-16-2012 02:47 AM in reply to: Anthony
If you want copy with base point for components you might be able to achieve similar results using iMates. Place as many components as you need in the assembly the hold Alt and drag and drop the iMate glyph (base point) to your constraint attachment location.
I would like to have a table or formula pattern. Basically a pattern where you can enter in varying distances for each component in the array. Similar to your offset option I guess.
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Message 15 of 138 (2,225 Views)
08-30-2012 02:08 PM in reply to: FProcp
Creation trace-ability.
It is sometimes very difficult to work out how a model has been created when working on other people’s 3D models.
We need more aids to teach us how someone else has created the 3D model you are now working on.
One aid could be when a sketch has been projected from another sketch, you could hover over and it would indicate the original point/line/sketch/part it was projected from?
Maybe all dimensions within the actual sketch could be one colour but dimensions to other geometry such as the origin or to other sketches/featues/workplanes could be different colours?
Maybe there should be a way to select something in the sketch that will highlight in the feature tree (or somewhere) the workplane it was created on or the surface it was created on?
Franc
inventor :-)
Message 16 of 138 (2,222 Views)
08-30-2012 02:13 PM in reply to: FProcp
Derive same part but with different dimensions
Have the ability to derive in a part and be able to change multi-value dimensions from that part.
Then you could have one master part file and many versions of it being derived versions of the master part but with different dimensions selected.
The dimensions could be set up as multi-value dimensions in the master part and allow them to be changed in the derived part.
Franc
inventor :-)
Valued Contributor
jeff.noel
Message 17 of 138 (2,208 Views)
08-30-2012 04:01 PM in reply to: FProcp
All I want in Inventor 2014 is bug fixes.  That is it.  It is one thing too if you only use Inventor, but once you throw Vault into the mix, you have just about the buggiest software I've ever used.  I spent far to much time helping out users work around bugs in Inventor/Vault than I care to do.
You don't know how frustrating it is when a user is trying to do something using the correct workflow, and Inventor won't let it happen, so you have to teach them some convoluted, backwards way to get around it, that would never normally be recommended to do, but since there are bugs preventing you from working properly, they have no other choice.
Trying to check in a file you've been working on?  Sorry, Inventor wants you to first save files you don't have checked out, and are unable to save.
Want to change states of a file you just opened?  Sorry, Inventor wants you to SAVE and CHECK IN a file that is currently NOT Checked Out and set to the "Released" state (in other words Inventor wants you to do the impossible).
Want to check in a new Library part you just added to your library folder?  Sorry, Inventor wants you to save a Library part (again, a file that CANNOT be saved), before you can check it in.  You try to use a project file that allows editing of library parts, but you can't check it in, because it isn't the proper project file for the Vault you are using.  So you save the library part and go to the correct project file to try and check it in, but for some reason Inventor thinks something has changed just from opening the file.
I know alot of these are Vault related, but they happen when working within Inventor.  Alot of the times the reasoning given for these problems too has to do with how Inventor treats files and how Vault can't handle it.  It seems to me Inventor and Vault are developed in their own little cages, but a product this complex needs to work together.  Inventor/Vault is almost a perfect example of what seems to be two product developement teams that don't work together to achieve the intended goal of the Software Suite, because those two programs seem to be fighting each other every step of the way.
So please, fix the software, because it is driving us CAD managers nuts.
Valued Contributor
jeff.noel
Message 18 of 138 (2,204 Views)
08-30-2012 04:03 PM in reply to: jeff.noel
I was looking forward to going home, but a user just e-mailed me a picture of a part they can't check in because Vault says that a file with the same name already exists, but doing a search of the entire vault for that file name, returns no results.  Yay......
Message 19 of 138 (2,196 Views)
08-30-2012 05:03 PM in reply to: jeff.noel
Jeff, do you have any inventor examples of bugs you typically have to provide work arounds for?
Here is one I can think of:
If you create a cut through multiple solids when you try to edit it and add more solids it will only allow you to select one solid, not multiple. The work around would be to change back to join then back to cut and reselect all solids. It used to work fine in 2012.
Stew, AICP
Active Contributor
Rory_M
Message 20 of 138 (2,158 Views)
08-31-2012 04:50 AM in reply to: Inv_kaos
Window select in the Presentation environment for me please!
Rory
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
