Good day beautiful people,
I have been using the Tube and Pipe tool on a daily basis for a few months running Inventor 2010. I recently installed Inventor Pro 2014 and it no longer works. As I click on the Tube and Pipe button, the Windows loading icon thing shows up and runs in circles until I manually stop it by closing Inventor thru the Task manager (printscreen attached). I tried this with a very light Assembly containing only 2 parts that I need to connect.
I understand this issue can have many causes and I actually don't expect a magical answer here (but who knows ?). I just posted this so this bug is now aknowledged. However, please submit to me any tip that you may find useful. Thanks in advance.
Inventor Pro 2014 64 bits / Build 170 / Release 2014 RTM
Windows 7 SP1
Intel Xeon CPU E5-1620 @ 3.60 GHz
8 GB RAM
Nvidia Quadro 4000
Good morning and welcome to the forums.
I'm afraid I can't reproduce this on my machine. Creating a pipe run seemed a little slow, but did work. Did you verify that piping runs.iam is in your Design Data folder, or some other place in your search paths?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for your quick answer Chris. I could not verify this point since I could not even create a pipe run. I called our helpdesk as well and the lady at the phone solved my problem.
She made me open the Windows Registry and go there :
HKEY_CURRENT_USER\Software\Autodesk\Inventor
Then she asked me to save the key "RegistryVersion18.0" (very important in case something goes wrong) and delete it. This key contains the Inventor user settings. Deleting it will cause your settings to be reset at their default values.
After that, I could create pipes and tubes.
One more thing : after that, I also lost my Color Templates in the Color tab. So she made me click on the file containing the key "RegistryVersion18.0" in order to add it back to the registry (it does not make much sense to me but who cares, it worked). Then I went to :
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0\System\Preferences
I saved the key "ColorSchemes" and deleted it.
Hope it helps !
EDIT : Since the person that helped me is not here, kudos to me, right ?
Wow... all that registry fixing makes it sound like something went horribly wrong during the install.
Yes, go ahead and give yourself a big pat on the back... buy yourself a beer.
Chris Benner
I had the exact same problem but your solution didn't work for me any other ideas ?
I ran across exactly the same problem, and the Registry suggestion didn't help either. What did work, oddly enough, was to create a blank assembly, save it with a dummy name, and open up the Tube and Pipe environment inside that assembly. Then, without quitting Inventor, open up the Tube and Pipe environment inside the assembly I wanted to work with.
Odd.
I had the same problem. Interestingly, I renamed my assembly file and it worked! give it a try.
I have the same problem.
I deleted the registry, I tried using a short file path without success.I saved the file with a new name...
It not depends of the files ..I also tried with the tutorial files The first 'AirSystemAssy.iam' in tube and pipe
Could you help me?
Thanks in advance
DR
You say you have the same problem, but several problems have been mentioned in this thread. Can you be more specific about what behavior you are seeing that you need help with?
Chris Benner
this is my case: in Inventor 2014 an assembly Starting in Environments
tab-> Tube and Pipe, I create a 'Run'( I left the default name in
dialog box) and I click OK,
in the lower left appears 'is Loading Presentation' (?) and I have to wait but the System does not respond. I have to kill it...
I tried also with the first tutorial file .
I tried with a short path of the data...(not in the desktop )
the project is correct..
PS: I checked the update..SP1
update 3 on Win Seven 64 .
thanks
SAVE BEFORE LAUNCHING TUBE AND PIPE!!
I forgot that the launching of tube and pipe environment is intermittent and lost some work due to having to restart Inventor.
First starting the tube and pipe in a blank assembly does work though.
This solution worked for me. Is not the perfect one but at least it lets me continue with my work.
