Hi!
I'm not sure I understand the whole work flow and issue. Could you elaborate a little further?
It sounds like you are trying to override the formatting of a column in a drawing's parts list, but there is an issue with units.
Is the issue that some parts were accidentally created with the wrong unit selected in the documents settings? When upgrading to 2014, did you migrate your sheet metal templates? Perhaps there was an issue migrating a template..
In the parts list are you displaying a custom parameter for the sheet metal parts? Are the parameters exported and formatted from the part?
I didn't see an attachment to that last post. Were you going to upload a file? Let me know if there's a problem and I can arrange for another method to transfer the data.
I think I understand this issue better. Let me run this description by you.
You have a custom content center library that contains a part template that should be in centimeter units. For the sake of this issue, let's say that the custom content parts are plates. These plates should each have a Length and Width parameter.
Whenever you place these custom content center plates into an active assembly, the part's document settings automatically revert to mm.
I noticed in the assembly file that the parts appear not only to have unit of measurement set to millimeter, but have been converted to sheet metal parts. Are you publishing the with a sheet metal part to the custom content center library? Does this issue occur if the template is a Standard Part Template and not a Sheet Metal Part?
Definately!
I would add the ilogic code to an assembly and then have the code recursively iterate through all the reference part documents to check that cm is set as the unit of measure. I think the below post has a bit of a head start on this conversation.
http://forums.autodesk.com/t5/Inventor-General/ILogic-rule-to-change-all-units/td-p/3710860
Check it out and let me know if I should look at anything else.
Thanks @Curtis_Waguespack!
Cheers,
We are seeing a similar problem with the display of Sheet metal extents in the parts list. It is showing correctly in the Text box but when used in the parts list and directly in the iProperty window the values appear in 'cm' not 'mm'.
We are on 2016 SP1. I confirmed the units are correct in each part and drawing.
Anyone found a fix?
Thanks in advance.
