I used to paste parts all the time while the constraints tool was open which made for a good work flow when I had to insert a lot of the same part. I just updated to SP1 and whenever I paste a part the constraint tool closes now.
Anyone else notice this or did no one notice/use the ability to paste parts while constraining?
Sadly (very sadly) Inventor never implemented a "good" way to place and constrain multiples of the same part...
This addin however is EXACTLY what you need and EXACTLY what Autodesk should have implemented YEARS ago.. Its well worth the $25 money.. (but there is a trial too)
http://www.kwikmcad.com/icode/KWiKSert_64/KWiKSert_64.aspx
I even offered a suggestion on how to implement that functionality into the constraint tool but they never went for it..
Steven,
I have used this workflow since Inventor R4. As far as I know, I have NEVER had a crash using the paste command with the constraint tool open. This is a tool that I use very often and I would be upset to see it go just because a few people were having problems crashing. You can't just start commands OUT (either intentional or not)!!
I am a little confused because I just tried the workflow and it still works. I am using R2014, Update2. I also went to the support page and noticed that there is only Update1 for 2014 Sp1. Was update 2 pulled for some reason?
Kirk
If you are on 2014 Update 2 you have not yet installed SP1 which is why it still works. There is now also an Update 1 for SP1.
I also used the paste option while in the constraint command on a daily basis for years and cannot remember ever crashing while doing it.
Regards
Martin
Steve,
You being a Sr. Principal Engineer, you are more than just a "messenger".
I can't emphaize enough how important this command it to our workflow. I do have the kwiksert on a few machines, but some others we have not purchased the license for it and the users use the paste tool while in the constraint command. The alternative is to just paste sevaral instances of the component and then start the constraint command. It just make it so much easier when you are zoomed in on an area and paste the item there. Otherwise, there is a bunch of zooming in/out just to place the component (mostly fasteners) becasue at times, they are inserted in several places around the assembly.
I can't believe that this was removed in a SP after it had been around for so long. However, I would be happy if something was worked into the constraint command to help with placing the same item multiple times (that is long overdue).
Kirk
