Okay, I'm having a lot of different issues it seems like...
First off, I believe I'm having issues with Inventor 2014, even more so than 2013.
Even doing a very simple sketch, Inventor seems to 'hang' and the little "Windows 7 loading ring" is on the screen, meanwhile, in the upper left-hand corner of my Inventor window, the (Not Responding) window header is visibile...
I go to the win7 Control Panel > Network and Internet > Network Connections > Local Area Connection... "Disable", then all of the slowness and hang-ups in Inventor, goes away, and everything is super snappy, just as it should be... I then "Enable" the network adapter again, it seems to be doing good for a few minutes or so of normal operation, then boom... back to more hang-ups and epic slowness. I can't for the life of me figure this out.
What info is needed for someone to be able to help me with this issue? Ps, our IT guys are worthless when it comes to Inventor stuff... They usually come to me for help 😕
So I'm here asking for someone, anyone's help...
I've pasted my recent "Inventor Diagnostics" clipboard copy-pasta, for everyone to browse over, if that might be of any help... But until then, I'm pretty much stuck working disconnected from the network and the interwebs, relying on all of my work e-mails to come through to me on my iPhone/iPad, here beside me at my desk... lol
Help! 🙂
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
AMD Radeon HD 7700 Series
Direct3D 10
Hardware Renderer
Graphics driver file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is version 8.17.0010.1172
Using Full optimization (this is the recommended setting)
The display is using 32-bit color
Inventor Version:
Build: 170, Release: 2014 RTM - Date: Thu 02/28/2013
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Routed Systems: Tube & Pipe
Mold Design
Design Accelerator
Frame Generator
Routed Systems: Cable & Harness
Drag & Drop Interoperability
Simulation: Stress Analysis
System Information:
Operating System: 64-bit Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: XPS 8500
BIOS: BIOS Date: 05/25/12 17:09:41 Ver: 04.06.05
Processor: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
System Memory: 32768MB RAM
Dedicated System Memory: 0MB
Shared System Memory: 16109MB
Dedicated Video Memory: 2005MB
Page File: 5287MB used, 63441MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7601.17514
Graphics Device Information:
DirectX Version: 10.0
Renderer: HAL
Adapter Description: AMD Radeon HD 7700 Series
DDI Version: 11
DDI Version Number: b
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Manufacturer: Advanced Micro Devices, Inc.
Chip Type: AMD Radeon Graphics Processor (0x683D)
DAC Type: Internal DAC(400MHz)
Revision:
Vendor ID string: 0x00001002
Device ID string: 0x0000683d
Graphics HW Memory: 1730 MB
Display Mode: 1920 x 1080 (32 bit) (60Hz)
VendorID: 1002
DeviceID: 683d
SubSystemID: 23041028
Revision: 0
Graphics driver file: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver file version: 8.17.0010.1172
Driver Date: 12/19/2012 16:08:04
WHQL Level: 1
Inventor Graphics Device Information:
Graphics Hardware Description: AMD Radeon HD 7700 Series
Hardware Library ID: Direct3D 10 \ 0x00001002 \ 0x0000683d
Direct3D Hardware ID: 1002 \ 683d \ 23041028 \ 0
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2013/01/15 11:05:45 $
HW Library OS Name = Windows 7 x64
Inventor Hardware Library Entry Information:
Autodesk Inventor Certification Status: Gold
Autodesk Inventor Tested Certification Status: Unknown
Graphics HW Vendor Supported for Autodesk Inventor: False
Hardware Library 2.0
Settings for optimized and conservative:
Workarounds: 0x00000000, 0x00000000
rating 4, optimization level 2
Texture Font Precision: 256
Display Information:
Back Buffer Format = DXGI_FORMAT_R8G8B8A8_UNORM
Depth Stencil Buffer Format = DXGI_FORMAT_D24_UNORM_S8_UINT
Monochrome Bitmap Format = DXGI_FORMAT_A8_UNORM
Graphics driver log information:
Oct/21/2013-14:09:08: Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
I am having the exact same problem. Has anyone found a solution for this issue?
Just curious are you working on a network with a virtualised server?
We had super crappy save times too. have that issue sorted by moving the data off the virtual server ( Server 2012 Essentials) onto the base server. Save times are fixed but still having lag/hang problems!
Help!
I came on the forums for the exact same reason. 2014 is running really slow on my machine but the 3 other machines are running fine. Even creating a simple tube take 20 seconds.... it took 2-3 before. I disconnected from my network completely and still no improvement. All other programs run fine.
Please help!
Oh yeh forgot to mention. As a workaround I have been using a 'Semi-isolated Workspace'. So you can still use the network for email, internet etc. Inventor seems to behave itself with data checked out locally to the pc. Checking everything back in is a pain and I forget sometimes. I have also had a few version issues with very complex assemblies with ilogic LOD.
I have the same problem. Inventor hangs up for about 30 seconds now and then. I can´t really see any pattern for the behavior.
What I have noticed is that the CPU is always at 12-14 % everytime this happends. And the program which is using all CPU is Inventor. The network connections in the Task manager doesn´t show any activity at all. The files are checked out so the computer shouldnt talk to the server. It sholudn´t be any network issue.
What happends?
Is there any properties which I could affect in Inventor for solving this?
the company should change their name to AutoCheck, because that is all they care about.
But let me try to answer the question:
The fix is to upgrade to the latest version of Inventor - 2014 is no longer supported. Please try 2016, and if you are still having issues, let us know!
smh.
This is a user-to-user forum, not the Autodesk Support.
Have you contacted your VAR?
What level of support did you purchase?
